 En stor bas igen..
Niklas Nord
Posted - 2002/10/31 :  18:40:05  Show Profile Send Niklas Nord a Private Message
SIMBA MJAU vilken kisse;
Simba
Posted - 2002/10/31 :  18:41:08  Show Profile Send Simba a Private Message
Originally posted by Niklas Nord
annars simba,
har du dessa..
JBL w15gti
Enig i at disse ser heftige ut, men er dem noe bedre??!! Neppe!! HVordan ser parameterne ut på dette beistet??!
Niklas Nord
Posted - 2002/10/31 :  18:44:53  Show Profile Send Niklas Nord a Private Message
här;
http://www.sound-creations.com/pdf/jbl/W15GTi_rev_f.pdf
Displacement: 0.174 ft3 (4.93 l) · Cut-Out Diameter: 13-7/8" (353mm)
· Overall Diameter: 5-1/4" (388mm) · Mounting Depth: 10-1/4" (260mm)
· Voice-Coil Diameter: 3" (76mm) · Frequency Response: 16Hz ~ 1kHz
· Impedance: 3 or 12 ohms · Power Handling: 800W RMS, 5,000W Peak
· Sensitivity: 92dB @ 2.83V/1m
Just as every performance automobile manufacturer has a racing division to test cutting-edge technology and engineering capabilities, JBL's GTi products push the limits of our engineering and technology group. The three Differential Drive Design (patent pending) GTi subwoofers are the result of a three-year effort to produce the best subwoofers money can buy. If you're looking for the absolute best in low-frequency reproduction, then you've come to the right place!
Suggested Retail Price: $1100.00
Differential Drive Design (DDD) motor
Die-cast vented basket
Kevlar-impregnated paper woofer cone
Nitrile-butylene surround
Power handling RMS: 800 watts
Power handling Peak: 5,000 watts
Mounting depth: 10-1/4"
Cut-out diameter: 13-7/8"
Dual 6-ohm voice coils
Sensitivity: 92dB
HUR SKULLE DEN TE SIG?
INTE SÅ VÄRST BRA, JAG HAR SIMULERAT..
FAST DE ÄR BILLIGARE I ENGLAND, I SVERIGE
CA EN 5500:-
Edited by - Niklas Nord on 2002/10/31 18:45:58
celef
sirap i datorn
Posted - 2002/10/31 :  19:29:52  Show Profile Send celef a Private Message
Aura, bra??
sound pollution
Nagref
Posted - 2002/10/31 :  19:48:54  Show Profile Send Nagref a Private Message
diffraktoriskt problematiskt...
VD för Acoustic Landscape
celef
sirap i datorn
Posted - 2002/10/31 :  20:03:59  Show Profile Send celef a Private Message
Jepp, worst case! :-)
sound pollution
Alexi
Ute och cyklar...?
Posted - 2002/10/31 :  20:44:05  Show Profile  Visit Alexi's Homepage Send Alexi a Private Message
JBL w15gti
Basars baksida blir bara snyggare och snyggare, känns som om man vill montera dom ut och in eller som isobaric
Driver forumet faktiskt.se
