 Nye produkter fra Accuphase
cybwiz
800.000-klubben
Posted - 2005/12/11 :  22:07:57  Show Profile  Visit cybwiz's Homepage Send cybwiz a Private Message
E-530 har blitt erstattet av E-550.
E-550 har fått AAVA volumkontroll og MCS+.
http://www.accuphase.com/pdf/e-550_e.pdf
PX-650 er en digital 6-kanals effektforsterker.
http://www.accuphase.com/pdf/px-650_e.pdf
http://cybwiz.blogspot.com/
Posted - 2005/12/11 :  22:27:28  Show Profile Send johan.björklund a Private Message
Digital förstärkare från Accuphase
Jag är mållös
Lite kul att AAVA sprider sig
*edit*
Nya options board har åxå kommit såg jag. Dax att byta DAC kanske då
Edited by - johan.björklund on 2005/12/11 22:34:21
Per100
Posted - 2005/12/12 :  08:35:29  Show Profile Send Per100 a Private Message
Vad är AAVA?
Posted - 2005/12/12 :  16:17:06  Show Profile Send johan.björklund a Private Message
Det är en deras volym kontroll som kom med C-2800. Den finns ny i ett par försteg o i den nya 550:an.
Saxat från C-2800:ans .pdf
The newly developed volume control called AAVA (Accuphase Analog Vari-gain Amplifier) is totally different from conventional controls using resistors. It allows
precise listening level adjustment while maintaining top-notch performance and sound quality over the entire range. Because the music signal does not pass
through variable resistors, it is not affected by changes in impedance. This means that high signal-to-noise ratio and low distortion of the signal are maintained.
Internally, a dedicated CPU selects the current switches that determine the gain of the amplifier. With regard to the music signal, the AAVA circuit is a fully analog
volume control.
 AAVA operation principle
AAVA operates by feeding the music signal to a V-I (voltage - current) converter
where it is weighted in 16 steps [1/2, 1/22, ... 1/215, 1/216]. The 16 current steps
are turned on or off by 16 current switches, and the combination of switch
settings determines the overall volume. The switching operation is controlled
by a CPU according to the position of the volume control knob. The combined
signal current forms a variable gain circuit that adjusts volume. Finally, the
combined current is converted back into a voltage by an I-V (current - voltage)
converter.
 AAVA resolution
AAVA adjusts the listening volume by means of 16 current switches. The
number of possible volume steps set by the combination of these switches is
2 to the power of 16 = 65,536. When maximum output voltage is 5 V, resolution
is an amazing 0.07 mV.
 Minimal distortion and no thermal noise
Because AAVA is an electronic circuit, the music signal does not pass through
any variable resistors. Thermal noise caused by resistors is totally absent.
Because there is no impedance that affects the signal, S/N ratio remains at
the logical optimum. The circuit configuration also assures ultra-low distortion.
 Simple circuit configuration
AAVA unifies the amplifier and volume control functions, resulting in a circuit
that is electrically very simple. Right and left channels are fully independent,
and frequency response does not change regardless of the volume control
knob position. Channel separation is excellent, and sonic performance remains
totally uniform over the entire range.
 AAVA means analog processing
The AAVA circuit converts the music signal from a voltage into a current, alters
gain by means of current switches, and then reconverts the current into a
voltage.
 Same operation feel as a conventional high-quality volume control
The actual volume control knob is linked to a variable resistor. However, this
resistor is only used to detect the absolute position of the knob. Operating the
control therefore feels exactly the same as with a conventional control, and
operation via the remote commander is also possible.
 Attenuator and balance control also realized via AAVA
The functions of the attenuator and the left/right balance control are covered
by the AAVA circuit as well, eliminating the need for additional stages. Keeping
the configuration simple helps to maintain high performance and sonic purity
cybwiz
800.000-klubben
Posted - 2005/12/12 :  17:48:03  Show Profile  Visit cybwiz's Homepage Send cybwiz a Private Message
Innsiden av PX-650
Delta Sigma digitale moduler; designet av Accuphase?
Edited by - cybwiz on 2005/12/12 17:49:48
ohmega
Posted - 2005/12/12 :  20:57:25  Show Profile Send ohmega a Private Message
Men är "AAVA" någonting nytt egentligen?...det är väl en Multiplicerande DA-omvandlare bara?
Snoop
Medlem, HiFi Norr
Posted - 2005/12/12 :  22:22:46  Show Profile Send Snoop a Private Message
PX-650 skulle man haft till framtida bio anläggningen, den är ju hur snygg som hellst.
Vad är det för pris på den
Moderator på Minhembio
Posted - 2005/12/13 :  00:04:12  Show Profile Send johan.björklund a Private Message
volume control.
Säger det mesta eller ?
thli
Posted - 2005/12/13 :  10:20:09  Show Profile Send thli a Private Message
Snyft, då är min E-530 "ute" nu då. Dax att uppgradera
//Thomas
ohmega
Posted - 2005/12/13 :  11:16:55  Show Profile Send ohmega a Private Message
Nu skall man hålla isär begreppen DA-omvandlare å DA-omvandlare
En "vanlig DA-omvandlare" som finns i en CD-spelare - fungerar ju i stort sätt genom att ha fast spänningsreferens som sen via det inkommande bitmönstret - fastslår utsignalens spänning- eller strömnivå ca 44100 ggr per/sekund. Utsignalen genereras således av digital information.
En "multiplicerande DA-omvandlare" kan använda sig av en varierande insignal som referensspänning. Å detta kan man utnyttja i förstärkare. Den analoga musiksignalen matas in som referensspänning - om vi då matar in ett bitmönster som består av 16 bitar....så styr bitarna hur stor utsignalen skall vara i förhållande till insignalen . Nån DA-omvandling i egentlig mening sker alltså inte.
Posted - 2005/12/13 :  14:52:12  Show Profile Send johan.björklund a Private Message
Jag har inte nämt DA i sammanhanget , jag vet inte ens att det finns nått som heter "multiplicerande DA-omvandlare"
ohmega
Posted - 2005/12/13 :  16:52:11  Show Profile Send ohmega a Private Message
Sant...jag tänkte dock att ordet "DA-omvandlare" skulle få folk att missförstå det hela...kan dock säga att det troligtvis är på det sätt jag tidigare nämnt. En "multipliserande DA-omvandlare" som används som volymkontroll. I ett byggprojekt som presenterades i "High Fidelity" för en 5-6 år sedan (hittar inte dom nummren bara för det).
Ett förförstärkarbygge kallat "AIR" om jag inte minns fel.
Jag mindes fel...efter ett par minuters grävande i mitt "arkiv" hittar jag: High Fidelity nr2(1998). PreFix hette bygget.
Där använde man sig av en krets som heter LTC1590 å tillverkas av Linear Technology
http://www.linear.com/pc/downloadDocument.do?navId=H0,C1,C1155,C1005,C1157,P1571,D4081
Denna "pryl" skiljer sig inte så mycket mot tex vad som benämns som: "Digitalt kontrollerad volymkontroll" exempelvis PGA 2310
http://www.elfa.se/elfa-bin/dyndok.pl?lang=se&vat=0&dok=8882.htm
