Vox
fd. Eric V-ås
3656 Posts |
Posted - 2005/12/04 : 14:42:40
Myryad MXI 2080 i nyskick säljes.
Nypris ~15.000 SEK Nupris 9.500 9.000 SEK exkl. ev frakt
Självklart finns fjärr, manual och originalkartong.
MXI2080 Continuous average power output 8ohm: 80 W 4ohm: 120 W THD (at 80% rated power, 8W, 20Hz-20kHz) 0.02% Inputs: Line Direct, Tape , CD-R, CD, Tuner, Outputs: Tape, CD-R, Bi-Amp, Preamp, Power Input sensitivity (ref. rated power)320 mV user trimmable 160-640mV) Maximum input level >8 Vrms Input impedance 22 kW / 200 pF Frequency response (20Hz - 20kHz) ±0.2 dB (-2dB @ 96kHz) Signal/Noise ratio (A-weighted, ref. rated power) >107 dB Preamp only Output impedance 220 W Maximum output level >8 Vrms Power amp only Input sensitivity (ref. rated power) 900 mV Input impedance 60kW / 440pF Physical Specification Dimensions (width x height x depth) 436 x 95 x 355 mm Weight Net: 11.0 kg Power requirements Voltage (set internally) 120 / 230 V
What Hi-Fi? Magazine (September 2005) tests seven high quality amplifiers between £950 and £1325.
The clear winner is the outstanding Myryad MXI 2080
"We have a new top dog in this prestigious category of hi-fi product, and what an amp it is! It delivers music with such honesty that you'll be lavishing it with praise for years to come."
What Hi-Fi? (September 2005)
"Om Gud ville att vi skulle lyssna på fler kanaler än 2 skulle han gett oss fler öron" |
Edited by - Vox on 2006/01/26 13:53:57 |
