 Gryphon Encore 2 x 500 watt
peak
Peak-Consult
Posted - 2005/08/03 :  22:53:52  Show Profile  Visit peak's Homepage Send peak a Private Message
2 x 500 Watts (8 ) and 2 x 1000 Watts (4 )
Pure Dual Mono configuration with two separate transformers and AC cords
Two 1300VA Holmgren toroidal transformers
160,000 F capacitor bank
Fully balanced topology with zero negative feedback and DC servo coupling
Ultra-short signal path with minimal internal wiring
Extensive use of Wima Polypropylene capacitors as power supply decoupling
16 High-current Sanken bipolar output transistors per channel
Zetex Input transistors
Double-sided printed circuit boards with 70 m copper
AC polarity indicator
Microprocessor controlled protection system
Upgradeable microprocessor software via "Keyfob"
PCB-mounted gold-plated Neutric XLR socket for balanced input
PCB-mounted gold-plated RCA sockets for single-ended input
Extensive mechanical decoupling
Weight: 48 Kg
Designed and built in Denmark
54.000 dkr
www.peak-consult.dk
