 Vifa M21WO-39-08
Dahlberg
Mästar-Harry 2005
Posted - 2005/05/21 :  21:15:13  Show Profile  Visit Dahlberg's Homepage Send Dahlberg a Private Message
Är det någon som har erfarenheter av den ?
Nominal impedance [ohm] 8
Voice coil resistance [ohm] 5.5
Nominal power [W] 80
Sensitivity [dB] 90
Frequency range [Hz] 25-3000
Free air resonance [Hz] 28
Voice coil diameter [mm] 40
Voice coil height [mm] 18
Air gap height [mm] 6
Voice coil inductance [mH] 1.0
Eff. diaphragm Area [cm²] 235
Moving mass [g] 23
Magnet weight [g]/[oz] 698/24.6
Force factor [Bl] 8.2
VAS [l] 105
Qms 1.97
Qes 0.35
Qts 0.30
Edited by - Dahlberg on 2005/05/21 21:26:57
nl
Posted - 2005/05/21 :  21:21:08  Show Profile Send nl a Private Message
Ett element jag är lite intresserad av. Ska hålla koll på tråden.
Creative Audio
Posted - 2005/05/22 :  00:54:48  Show Profile  Visit Creative Audio's Homepage Send Creative Audio a Private Message
vifa P 21 WN Preis: EUR99.00
Nominal Power (IEC#268-5) : 80 W
Frequency Range : 25-4000 Hz
Sensitivity (1W, 1m) : 89 dB
Nominal ImpedanceZn Zn: 8 Ohm
DC ResistanceRe Re: 5,7 Ohm
Voice Coil Inductance Le: 0,9 mH
Resonance Frequency fs: 28 Hz
Mechanical Q Faktor Qms: 1,60
Electrical Q Faktor Qes: 0,52
Total Q Faktor Qts: 0,39
Moving Mass (incl. air) Mms: 22,5 g
Effective Piston Area Sd: 235 cm^2
Force Factor Bl: 6,6 Tm
Equivalent Volume Vas: 113 L
Speaker Diameter : 215,2 mm
Whole Diameter : 187 mm
Speaker Depth : 81 mm
Speaker Weight : kg
Basket Material : Magnesium
Magnet Diameter : 92 mm
Magnet Weight : 0,4 kg
AirGap Height : 6 mm
Voice Coil Height : 14 mm
Voice Coil Diameter : 40 mm
Voice Coil Carrier : Alu
Ferrofluid : no
Cone Material : Polypropylen
Surround Material : Rubber
Kanonhögtalare för det priset
wolfgang
http://www.creative-audio.se
Dahlberg
Mästar-Harry 2005
Posted - 2005/05/22 :  00:58:05  Show Profile  Visit Dahlberg's Homepage Send Dahlberg a Private Message
Inte samma som jag frågade efter.
Creative Audio
Posted - 2005/05/22 :  01:07:31  Show Profile  Visit Creative Audio's Homepage Send Creative Audio a Private Message
Förlåt Dahlberg , den var över den andra på sidan; www.hifish.de
Wolfgang
Dahlberg
Mästar-Harry 2005
Posted - 2005/05/22 :  10:09:34  Show Profile  Visit Dahlberg's Homepage Send Dahlberg a Private Message
Tack för att du försöker hjälpa till även om det blev lite tokigt
Det verkar som att det går att diskutera priser på den här.
Framför allt vid större kvantiter. Precis som vanligt alltså
http://www.bmm-electronics.nl/Product.asp?Product_ID=3668
Posted - 2005/05/22 :  11:42:22  Show Profile Send EngelholmAudio a Private Message
Pratar vi större kvantiter går det självklart att prata priser... harke-host-harkel...
Posted - 2005/05/22 :  12:26:34  Show Profile Send jonasz a Private Message
Om du har lust att importera så tar Madisound 365kr st för dem. Vet inte om de har mängdrabatt. Visserligen kommer frakt och moms till men det lönar sig nog om du ska ha många. I den holländska länken ovanför kommer ju deras moms (19%) till också om jag lyckats tyda det rätt.
http://www.madisound.com/vifa.html
http://www.madisound.com/pdf/vifa/m21wo-39-08e.pdf
Jonas
Dahlberg
Mästar-Harry 2005
Posted - 2005/05/22 :  14:41:52  Show Profile  Visit Dahlberg's Homepage Send Dahlberg a Private Message
Priset går nog att få ner till tilltalande nivåer men att köpa
på sig nått i stil med 16st utan något annat än ett datablad
känns lite väl chansartat. Ingen som har provat den
