 Det är inne med LinjeKällor!!
Niklas Nord
Posted - 2002/10/13 :  22:32:20  Show Profile Send Niklas Nord a Private Message
här kommer en riktig jamare med raven och seas;
http://www.alonbyacarian.com/products/exoticagr_b.htm
SPECIFICATIONS
Overall System
Frequency Range: 16 Hz to 45 kHz Transducers: 46
Output: 120 dB from 20 Hz to 20,000 Hz Amplifiers: Four channels required, up to eight channels may be used
Total magnet weight: 110 LB MSRP: $120,000 system
Main Tower
Frequency range: 40 Hz to 45 kHz Sensitivity: 90 dB @ 2.82 volts
Impedance: 8 ohm / 7 ohm minimum Connection: 3 pair solid copper 5 way binding posts for tri-wire
Maximum Power: 700 watts per channel program Dimensions: 12 inches wide, 84 inches high, 16 inches deep
Weight: 300 LB Finish: Matched Select Santos Rosewood. Std. Other finishes optional
Subwoofer Tower
Frequency Range: 16 Hz to 40 Hz, controlled by Variable Low Pass Filter Sensitivity: 99 dB @ 2.82 volts
Impedance: 1 Ohm minimum Maximum Power: 1000 watts per channel program
Connection: 1 pair solid copper 5 way binding posts Dimensions: 13 inches wide, 84 inches high, 26 inches deep
Weight: 300 LB Finish: Matches Main Tower
Nagref
Posted - 2002/10/13 :  22:35:25  Show Profile Send Nagref a Private Message
Ser j*vligt snygga ut!
VD för Acoustic Landscape
Niklas Nord
Posted - 2002/10/13 :  22:42:21  Show Profile Send Niklas Nord a Private Message
Dock, kostar 120 000$ och det är rätt mycket.
snygga, ser okej ut faktiskt.
undra sa flundra om det kan vara lambda basar..
celef
sirap i datorn
Posted - 2002/10/13 :  23:38:06  Show Profile Send celef a Private Message
Om man klädde dem med en strumpa skulle de se ut som nån tidig Mirage...
sound pollution
Revisorn
Posted - 2002/10/14 :  09:15:01  Show Profile Send Revisorn a Private Message
Snygga?? Njaää va. Big is beautiful? De skulle se lite mastiga ut i mitt hem i alla fall.
Alexi
Ute och cyklar...?
Posted - 2002/10/14 :  14:01:14  Show Profile  Visit Alexi's Homepage Send Alexi a Private Message
Vad får dig att tro det?
Det kan ju vara något special gjort av Nick, men dom ser inte ut som Lambdas framifrån iaf.
/Alexi
Stolt ägare av 4st Lambda 15"are
Driver forumet faktiskt.se
Niklas Nord
Posted - 2002/10/14 :  15:52:26  Show Profile Send Niklas Nord a Private Message
Aha, känner du honnom, Nick??, jag mailar honnom och frågar
om det är lambda, det kan vara intressant att veta..
kan jag hälsa från dig, kanske är hemligt annars!
n/a
deleted
Posted - 2002/10/14 :  16:04:03  Show Profile Send n/a a Private Message
Ser rätt bra ut!!
Alexi
Ute och cyklar...?
Posted - 2002/10/14 :  16:18:19  Show Profile  Visit Alexi's Homepage Send Alexi a Private Message
Det är mycket hemligt tyvärr. Det ingår i hans avtal med sina "kunder" att det inte ska skyltas med vem som gjort ellementen.
Alexi
Ute och cyklar...?
Posted - 2002/10/14 :  16:43:24  Show Profile  Visit Alexi's Homepage Send Alexi a Private Message
På tal om Linjekällor så har ju det funnits ett tag här ett par utomordentligt fina saker anno 1980:
Edited by - Alexi on 2002/10/14 16:44:50
