 vienna accoustics
Rene
Posted - 2005/01/11 :  21:20:56  Show Profile  Visit Rene's Homepage Send Rene a Private Message
så er vienna klar med den nye center MAESTRO og all speaker WALZ .
Der er kommet nye driver og frontstof samt nye finis
MAESTRO 38-22000Hz 6 Ohm 91dB 30 - 200 Watt Bass refleks
590 x 172 x 291
1 x 1" Scan Speak diskant, silke dome.
2x 5,5" SEAS XXP membran driver for
mellemtone og bassområdet
WALZ 70-2000Hz 4 Ohm 91dB 25 - 180 Watt Trykk kammer 200x480x95mm 8,0 Kg
1 x 1" diskant, silke dome.
2 x 5,5" mellemtone og mellembass.
Samt en ny model i ders aluline .
Trio Er en 3 i 1 speaker L Center R mål 840 x 265 x 90 mm
ORATORIO center og STRAUSS forbliver som de er .
ORATORIO 30-30000Hz 4 Ohm 91dB 50 - 300 Watt Bass refleks 750x235x360mm 27,0 Kg
1 x 1" VA diskant, silke dome.
1 x 7" karbonfiber fylt membran for mellemtone
2 x 9" VA basser med karbonfiber fyldte mebraner.
www.vassagohifi.dk
Edited by - Rene on 2005/01/12 23:29:11
Rene
Posted - 2005/02/02 :  10:37:37  Show Profile  Visit Rene's Homepage Send Rene a Private Message
Såden ser nye line ud , mozart Beethoven classis Beethoven Grand MAESTRO HAYDN
www.vassagohifi.dk
Rene
Posted - 2005/02/07 :  12:30:34  Show Profile  Visit Rene's Homepage Send Rene a Private Message
lidt om den nye Haydn Gran
I får det på eng .
HAYDN (Concert Grand Series)
Technical features
Exceptional invention of frontporting bass system construction in combination with tweeter giant chamber solution.
Frontporting – Avoiding of all doubts of customers and endconsumers regarding any porting on the rearside and its implications on questions like necessary distance near the wall and troubles in a bookshelf.
The unique construction works by a inner reflexpipe, approaching a wedge. The cutting-line of the wedge devides the airflow into 2 streams, which then flow in a specially designed and extensively optimized flare. The distance of wedge and flare is of critical importance. The results are a) maximum bass support by the porting system and b) the reduction of all porting-caused standing waves by – 12dB as the wedge effectively works as an obstacle for high frequencies (=noise), but as a support for low frequencies (=bass output as support for driver and bass impulses).
All parts of the whole construction are massive Aluminium, produced by expensive high pressure die-cast tools.
The wedge fulfills a very welcome function at the same time: Its high volume is used as a huge chamber for the tweeter. The specially designed tweeter for this construction profits from unconstrained air-decompression approaching conditions of free-field. In our development we came up with the best sounding solution of air-pass by complete opening not by central hole, but by an allaround circle slit. This results in optimal use of the chamber volume, whose volume by the way surpasses any conventional tweeter-construction. Thereby the tweeterdome operates unconstrained even into the lower midrange.
As always the best results were achieved by handcoated silk dome, and a specially developed ferrofluid damping in combination with a super-light voicecoil of 4 Ohms. Main result of development: extreme resolution of finest high frequency impulses while achieving perfect midrange warmth and clarity.
New development of a 6” bass/midrange driver with new VA proprietary mixture “X3P” of TPX and 3 polypropylene based synthetics, maximum inner damping.
Inverted rubber surround, breakthrough in no-loss damping.
Completely new crossover layout, with copperpaths in direction of electrons-flow.
New Gold- and Silver-terminal for lowest transition resistance.
New Cables: 2 drilled cables with maximum single-copperwires thickness.
New cabinet in bigger size than before: 174 x 361 x 265 mm (before 170 x 345 x 255 mm)
Cabinet with massive baffles, 45% thicker than previous model, for maximum rigidity.
Veneer-wrapping technology on Maple, Cherry and Rosewood.
Black available in true Piano lacquer, accommodating any living room.
Innovative new and unique grille: We invented a grille which for the first time does not influence the sound in an adverse way due to its built-in phase diffusor. In front and center of all drivers it acts as a dispersion for the sound waves, benefiting the soundstage, both in depth and stereo imaging. It can even be used as a possible tuning device for the dedicated highend fan fighting for the last percent of performance. Please note the extensive efforts for the tweeter on the milling on this phase diffusor.
The grille is full Aluminium.
Besides this new grille results in outstanding elegance and beauty on the appearance of the speaker.
Data
Impedance 4 Ohms
Frequency Response 42-20000 Hz
Sensitivity 89 dB
Recommended Amplifiers 25 - 180 Watts
Drive Units
6” Bass/Midrange Driver X3P Cone, transparent
1 ” Dome-Tweeter hand-coated VA Silk Dome
Bass System Bassreflex, Frontported
Bass Function Impulsoptimizing QB 3 Quasi Butterworth)
Crossover Components
MKP Capacitors 1% tolerance
Coils 0,7% tol., Exclusively Air Coils
Metal Film Resistors, 1% tol., inductance free
Crossover Function 2-way 6 dB and 12 dB Bessel
Weight per Pair 20 kg
Dimension (W x H x D) 174 x 361 x 265 mm
BEETHOVEN CONCERT GRAND den store beethoven
BEETHOVEN GRAND den lille beethoven er klart i mars
MOZART Grand: klart i mars
BACH Grand: klar i aut
HAYDN Grand: er klar
MAESTRO Grand: er klar
WALTZ Grand: er klar
www.vassagohifi.dk
