 *SÅLD*Sonus Faber Musica integrerad förstärkare
armani
Posted - 2004/12/03 :  08:49:34  Show Profile Send armani a Private Message
Nypris 35.000:- ge bud
Musica is the perfect expression of the Sonus faber philosophy, embodying simplicity while representing the quest for the finest sound reproduction possible. This pure and simple design, while state-of-the-art in terms of technology, contrasts with the sophisticated technical considerations applied in its conception and construction. In creating this precision instrument, Sonus faber did not regard absolute power as a design objective, but instead concentrated on musicality, involvement and emotion. In a sense, Musica has been designed by music lovers, for music lovers.
Power Output: 100 watts x 2, 4 ohms / 50 watts x 2, 8 ohms
Amplifier Features: Left / Right Channel symmetrical PCB design
Surface Mounted Device (SMD) technology for shortest signal path 28 dB total gain
Dual JFET differential input with double bootstrapping
Error corrected MOSFET output stage
Low impedance dynamic drive capability
DC short circuit and thermal protection circuit
Six line inputs
Buffered record output
Custom made plastic conductive volume control
No tone controls for signal purity
Mechanical input selector with switched ground line
WBT gold-plated speaker terminals
Power Supply Feautures: Torodial type transformer
Custom twin 1500 mF low multiplication factor main capacitors
Independent power supply for input gain stage and output stage
Ultra high speed schottky diode rectifier in double bridge configuration for input and output stage
Discrete voltage regulators for input gain stage
Finish: Front panel in solid walunt or black finish. Controls and spikes in gold plated copper
Dimensions: 17 x 13.5 x 6 inches (WDH)
425 x 335 x 155 mm (WDH)
Weight: 35.2 lbs / 16kg
Edited by - armani on 2004/12/05 08:44:10
