 eAR Two Plus
Figge
Posted - 2004/11/25 :  11:25:54  Show Profile Send Figge a Private Message
Kan detta var ett alternativ? Att lyssna på? Någon som har ett
eAR Two Plus?
eAR® Two Plus power amplifier 2-channel power amplifier.
Performance level The giant killer that resets the standard for any stereo power amplifier in the world.
Max. power output (RMS) 2 x 500W / 4#937;, 2 x 250W / 8#937;, max. 1700 Watt RMS short term into very low loads
Power stage efficiency > 93%, 200W / 8#937; (only ICEpower)
Peak output current More than 80A (0.6#937;), max. 130A
Output impedance 5m#937; @ 1kHz
Dynamic range >119dB
THD+N < 0.002%
Linearity 10Hz - 20kHz: +- 0,2dB
Bandwidth 5Hz - 90kHz
Input sensitivity (full output) 2V RMS
Input impedance 50 kOhm
Gain 30 dB
Inputs, selectable 2 x Balanced XRL and 2 x single-ended RCA
Outputs Touch proof WBT
Dimensions (WxHxD) 380x130x280 mm
Shipping weight 12kg
Någon som hört detta steg?
