 Dr Gizmo Rosenberg död
time
Harry-vinnare 2004
Posted - 2004/11/21 :  18:27:18  Show Profile Send time a Private Message
Är jag den enda som missat detta sorgliga ? kolla sida meta-gizmo.com , mycket läsvärt om livet och trioderna, speciellt the Triode Guild. Lite utanför vårt DIY men ändå..
Lämnat forumet
Posted - 2004/11/21 :  18:29:03  Show Profile  Visit Bernt Jansson's Homepage Send Bernt Jansson a Private Message
Trist. Det var ju verkligen en profil, särskilt för en OTL-freak.
time
Harry-vinnare 2004
Posted - 2004/11/21 :  18:33:39  Show Profile Send time a Private Message
Just det, en som förde fram Julius Futtermans ideer, dessutom förbaskat rolig, en man som förstod vad som var det viktigaste i livet, rör. kvinnor och manliga maskiner...
Lämnat forumet
Posted - 2004/11/21 :  18:37:55  Show Profile  Visit Bernt Jansson's Homepage Send Bernt Jansson a Private Message
Sätter in en bild med tillhörande text som får symbolisera denne säregne man:
"THE BLACK HOLE AMPLIFIER™
In the mid 1980s the mega-amplifier wars were raging, and, as you know, I am very competitive, and I wasn't going to let some mealy minded designer of sand amps win the war, so I invented the world's only amplifier that was powerful enough to accurately reproduce the Voice of God, in the denomination of your choice.
This amplifier, as you can tell from the picture was huge….six stories high, and boasted some very unusual features…just to name a few:
You notice a 90 mm Howitzer Canon on top of the amplifier next to the tubes…this is the output stage protection device, and prevents any enemy planes from attacking.
The cooling tower not only keeps the output tubes running at the proper temperature but also provides the liquidity for the midrange and the speedboat you notice at the base of the amp.
All of the dials permit the owner to select the religious experience of his choice.
If you are looking for me, I am the figure in the lower right hand corner.
Able to produce 10 million watts into 0 ohms from DC to light, at minus 10% total harmonic distortion , this amplifier is a bargain at $267 million dollars.
This amplifier can not be sold in California because of pollution laws because it is powered by its own surplus US Navy submarine nuclear reactor.
You should be aware that The Black Hole eats big transistor amplifier for snacks at 3PM every day, with ten thousand gallons of fresh milk.
If you are a man who must own absolutely the most powerful amplifier, or if you are using some of those very popular 0 ohm speakers, this is the amp for you.
A small down payment of $1 million in unmarked bills in a brown shopping bag, or…why not charge it on your credit card?
Be the first on your block to own a Black Hole Amplifier.
This amplifier received RECOMMENDED COMPONENT by the Pope, the Chief Rabbi of Jerusalem, and Wanantankah.
Schematic available on request."
Citatet från http://www.meta-gizmo.com/Tri/nyal/bl_hole_amp.html
Edited by - Bernt Jansson on 2004/11/21 18:46:12
secanbj
Posted - 2004/11/21 :  19:23:28  Show Profile Send secanbj a Private Message
inte för att verka petig men enligt sidan så är det ju 3 år sedan han flyttade till de sälla jaktmarkerna.
/Anders
time
Harry-vinnare 2004
Posted - 2004/11/21 :  19:50:24  Show Profile Send time a Private Message
Tiden går fort och det gäller att samla på sig visdom innan liemannen ringer på dörren... kolla tex detta www.meta-gizmo.com/Tri/june/SEX.html det är ont om dem som har kollen Secanbj, Icke desto mindre anledning.....
Lämnat forumet
Posted - 2004/11/22 :  00:04:21  Show Profile  Visit Bernt Jansson's Homepage Send Bernt Jansson a Private Message
3 år... OK, men det var ju synd ändå.
