 Scaler UP1280HD till projektor m.m
Guldis
Posted - 2004/11/13 :  13:20:24  Show Profile Send Guldis a Private Message
Säljer min 1 månad gamla scaler. Har bytt projektorn till en plasmaskärm med inbyggd scaler. Den är mao överflödig.
Köpt av Sisaco i Sthlm. Nypris 8500:-
Säljes nu för 6000:-
Kablar som medföljer är komponent, svhs och composit. Fjärr. Kvitto o garanti finns självklart kvar.
Datablad på scalern
http://www.sisaco.se/katmtrl/P1183.pdf
Info:
The UP-1280HD is an advanced upconverter with some outstanding features like digital noise reduction, adaptive static detect de-interlacing, dynamic color transience improvement, 3D adaptive comb filter and pixel based motion detection and a resolution of up to 1280 x 1024 (SXGA) resp. 720p/1080i. Features usually not even found in the most expensive Video processors.
The UP-1280HD functions as a resolution multiplier and upscales video to the full native resolutions required by today’s LCD monitors, LCD/DLP projectors and high-resolution plasma display panels. Visible scan lines and flicker are eliminated and the result is a picture with greatly improved detail and color quality.
The UP-1280HD accepts interlaced PAL/NTSC Composite Video, S-Video and YCbCr Component Video input signals. Its output (VGA or YPbPr) is pure, flicker-free, progressive video that is optimized for high-definition display.
With an easy-to-use infrared remote control and multi language on-screen display the UP-1280HD is not only a state of the art product but also very user friendly.
