 Jamo AVR-693/AVR-793
orthanc
Posted - 2004/11/05 :  09:25:33  Show Profile Send orthanc a Private Message
The big difference between the two new receivers is that the AVR-693 is a 6.1 channel model, delivering 6 x 120w (6 ohms) while the AVR-793 is a 7.1 channel device, delivering 7 x 135w (6 ohms). That said there are plenty of common themes...
Massive toroidal transformers and high-grade capacitors
The AVR-693 and AVR-793 feature overspecified toroidal transformers and high-grade capacitors (AVR-693: 40,000 µF, AVR-793: 60,000 µF), for extra stability and large reserves of power.
http://www.jamospeakers.com/media/press/release.php3?id=DF8AC9DED2B4A6680957619B6492027420041018112225
Undersöker för tillfälle.
