 Egglestone är grymma!!
Niklas Nord
Posted - 2002/06/26 :  11:41:11  Show Profile Send Niklas Nord a Private Message
Egglestone IVY !!
En av världens mer imonerande högtalare, jag skulle GÄRNA vilja höra en sådan. Jäklars, vore ett grymmt DIY projekt att klone dessa, och kanske det DYRASTE DIY projektet någonsin. 23 drivers per sida. basarna är push pull 3ggr per bas, likaså mellanregistren.
ETT PAR = 46 HÖGTALARE ATT DRIVA:)
Va det Esostar, men vilka mellanregister och basar? jaja, skit i det, kolla in bilden jag bifogar;
Visst är de fina, italiens GRANIT på utsidan.
Jag har aldrig sett någon bild, där dessa vart i hemmamiljö, kanske står de i nån studio, eller bara på mässor.
men HåLL MED, det är en rejäl, och vacker högtalare.
-Frequency response is from -4dB @ 13 Hz to well beyond 24,000 Hz.
-Efficiency is 87dB.
-Impedance is 7 Ohms, nominal. Minimum impedance is 5 Ohms.
-Tweeter: Two 1" cloth domes stacked back to front. Each tweeter has a large-diameter vent on its pole piece and a big aperiodic damping chamber that imitates an infinite baffle loading. Stacking them doubles the size of the pole piece across the same driver surface area, increasing linearity and power handling, while having no effect on frequency response. The tweeters are manufactured on a special production line under laboratory conditions.
-Mid-bass: Twelve 6" polypropylene, double-magnet driver, with a 3" voice coil diameter. Extremely rigid structural physics and the piston-like action of this driver produce exceptionally quick transients and a complete absence of coloration. These drivers are run full-range in four independently tuned transmission lines. Each transmission line contains three drivers in a pressure driven design, mounted front to back. The rear drivers reduce backpressure on the baffle-mounted drivers, simulating a free air resonance while simultaneously increasing linearity and power handling.
-Bass: Nine 12" woofers loaded in three parallel chambers. Each chamber consists of three woofers firing in a pressure driven configuration. The rear drivers reduce backpressure on the baffle-mounted drivers, simulating a free air resonance while simultaneously increasing linearity and power handling. The rear drivers are vented out the back of the enclosure through 4" ports.
-Enclosure: The extremely heavy enclosure becomes slightly wider as the speaker gets deeper on the bass enclosure and slightly narrower on the high frequency section. This minimizes parallel wall interactions, while increasing rigidity and stability.
-Internal wiring is manufactured by Transparent Audio.
-Single Cardas rhodium binding posts.
-The crossover for the tweeter is hard wired. We utilize Hovland MusiCaps and Vishay resistors.
-Damping material or stuffing is Acousta-Stuff, a nylon polyamide loose bulk fiber that is tri-lobal (instead of round) and multi-directionally crimped so that the strands interlock to form a very cohesive mass that does not require support and will not settle.
-The grills are made of an extremely transparent material that is stretched over a thin steel frame. They attach via magnets that are buried under the surface laminate, allowing the speakers to look as finished with the grills on as with them off.
-Black Italian granite is utilized.
-Special designed castors are permanently mounted to the base and are an integral pert of the design.
-The footprint is 15" wide on the baffle, 18" wide on the back panel. It is 36" deep, and 76" tall
-Net weight, per loudspeaker, is 790 pounds.
!!Om någon undrar varför jag skriver så mycket, så beror det på att det typ inte finns nått att göra på jobbet över sommaren.. Helt dött. och vad ska man göra? Jag sitter och läser en massa på nätet. Fast att surfa är så jäkligt tråkigt.. usch... nu får det bli vinter igen... .... ... Ack, den här databasen skulle man kanske...
När Tigern Springer Ur Djungeln; Springer Djungeln Ur Tiger
j.persson
Me, Myself & I !!
Posted - 2002/06/26 :  12:13:19  Show Profile Send j.persson a Private Message
Och jag som tyckte att LTS-f3-v4 hade många element med fyra åttor i basen...
Tror mellanregisterelementen är Morel och tolvorna är Dynaudio. Det finns en test av ett mindre syskon till högtalaren att läsa på Stereophiles sajt.
Jonas Persson
Morello
Posted - 2002/06/26 :  14:26:37  Show Profile  Visit Morello's Homepage Send Morello a Private Message
Att driva mellanregistret utan delningsfilter är ett tilltag som förvånar.
Joe Morello
-Time Further Out-
matson
formerly known as...
Posted - 2002/06/26 :  14:35:49  Show Profile Send matson a Private Message
Angående skumma designer såg jag denna från AudioPhysic:
Audio Physic showed a prototype of the Kronos loudspeaker, which will be priced at €40,000 per pair. The Kronos is intended to be a replacement for the company's current flagship, the Cerubin. The speaker features side-firing woofers on both sides of the cabinet (four in total), as well as side-firing midrange drivers (two per speaker). The only front-firing driver is a coaxial unit (shown below). The woofer section in this speaker is powered. A completely passive model will be released (name to be announced) based on the Kronos' technology, and company reps say that this new speaker will eventually replace the existing Caldera.
Sen detta element som sitter i!!!
The front-firing coaxial driver of the Kronos has a secondary back basket for mounting the driver more firmly inside the cabinet. The tweeter has a unique suspension system to align it in front of the midrange driver.
Pris: 40000 Euro, så det blir nog ingen sån i år.....
'Son, Never try because trying is the first step to failure.' -Homer Simpson
matson = JagÄrJoeLabero
Morello
Posted - 2002/06/26 :  14:40:17  Show Profile  Visit Morello's Homepage Send Morello a Private Message
Jösses.
Linn har också monterat diskanten framför mellanregistret.
Det innebär att vågen från diskanten moduleras av mellanregistret med tillhörande doppler-distortion.
Det verkar inte alltför genomtänkt
Joe Morello
-Time Further Out-
matson
Posted - 2002/06/26 :  14:47:27  Show Profile Send matson a Private Message
Genomtänkt tror jag nog det är, men jag fattar ingenting. AudioPhysic har ju lite roliga lösningar, som att dela Scanspeak diskanter under 1500 Hz och sånt där....Det hade varit kul att höra den dock, men den dyker väl inte upp i Sverige!
Morello
Posted - 2002/06/26 :  14:51:51  Show Profile  Visit Morello's Homepage Send Morello a Private Message
Egglestone skriver ju att mellanregistret drivs utan filter.
Det betyder att nästan all effekt under mellregistrets passband "eldas" upp. Vidare komemr förstärkaren att belastas onödigt mycket. Den är inte genomtänkt.
Har hört att Egglestone inte låter speciellt hänförande.
Joe Morello
-Time Further Out-
matson
Posted - 2002/06/26 :  14:58:30  Show Profile Send matson a Private Message
Aha, fel av mig. Jag trodde du refererade till AudioPhysic högtalaren.
Egglestone vet jag inget om, mer än att högtalaren ser "överdriven" ut!
Morello
Posted - 2002/06/26 :  15:03:01  Show Profile  Visit Morello's Homepage Send Morello a Private Message
Jag syftade på båda högtalarna.
Dom är konstiga på olika sätt.
Joe Morello
-Time Further Out-
matson
Posted - 2002/06/26 :  15:16:04  Show Profile Send matson a Private Message
Konstig kan jag hålla med om, men bra/dålig avvaktar jag med tills jag hört den(vilket inte kommer hända förmodligen).
AudioPhysic är en av få(kanske den enda) tillverkare, som använder SS element med (imho) bra resultat.
Sen gillar jag ju artikeln på Speakerbuilding också med "huvuddesignern" för AP.
Morello
Posted - 2002/06/26 :  15:30:08  Show Profile  Visit Morello's Homepage Send Morello a Private Message
Vad heter han?
Joe Morello
-Time Further Out-
matson
Posted - 2002/06/26 :  15:37:25  Show Profile Send matson a Private Message
Joachim Gerhard heter han.
http://www.speakerbuilding.com/content/1039/
Morello
Posted - 2002/06/26 :  16:06:45  Show Profile  Visit Morello's Homepage Send Morello a Private Message
Tackar!
Joe Morello
-Time Further Out-
Denna sida genererades på 0.54 sekunder. Snitz Forums 2000
