 DVDO Iscan High Definition
armani
Posted - 2004/06/17 :  13:49:02  Show Profile Send armani a Private Message
helt ny i kartong men öppnad nypris endast direkt från distributör 15.000:- mitt exemplar 12.000:-
fixar 1080P bland. annat
kan ev. ta en Ultra som inbyte
The DVDO iScan HD is a high-resolution video scaling processor & hub that converts standard-definition video content from your DVD player, VCR, PVR, satellite receiver, game console, or PC to any output resolution between 480p and 1080p, including the popular HDTV resolutions such as 720p and 1080i.
The iScan HD brings a host of new Video Scaling features to the DVDO iScan product family, while adding robust Digital Audio switching, routing, and processing technology. For the sophisticated home theater, and audio/video presentation systems, the iScan HD makes the perfect centralized control and processing hub.
Complete Audio/Video Hub & Scaler for Plasma display panels, HDTV-ready TVs, Projectors, Home Theater
Precision Video Scaling™ by Anchor Bay Technologies - yields best-in-class front-of-screen performance
Upconverts 480i and 480p video sources & content to high-resolution formats
Creates ANY user definable output resolution between 480p & 1080p, including the popular HDTV resolutions 720p & 1080i
Flexible Digital Audio switching and routing - four Digital Audio inputs, two Digital Audio outputs
Precision AV LipSync™ intelligent Digital Audio delay technology - precisely matches audio & video timing
AutoCUE-C™ - Automatic Chroma Upsampling Error Detection & Correction
AutoVFR™ - Intelligent Component video inputs featuring ABT's Automatic Video Format Routing™
AutoSource™ - Automatic Source Activity Detection & Selection
RightRate™ High-performance Framerate Conversion & full-frame Timebase Correction
Analog and digital DVI inputs & outputs
Future-proof design with upgradeable software
Infrared remote control with direct access codes
RS-232 automation/control interface
Technical Specifications
Inputs
Eight video inputs
Two Composite inputs accept standard NTSC, PAL, and SECAM signals
Two S-Video inputs accept standard NTSC, PAL, and SECAM signals
Two Component Video inputs (YPbPr or RGB/S) process 480i, 480p, 576i, 576p signals; pass-through 720p and 1080i High Definition signals
One VGA Analog Passthrough input - VGA HD-15 connector
One DVI input - DVI-I connector
Four digital audio inputs - can be assigned individually to any of the video inputs:
Two Digital Optical inputs
Two Digital Coaxial input
Accepts S/PDIF Dolby Digital, DTS, LPCM @ 44Ksps to 96 Ksps, 16 bits to 24 bits
Outputs
One Digital Video Output - DVI-I connector
One Analog Video Output - VGA HD-15 connector
RGB or YPbPr colorspace
Separate H&V sync, composite sync, or sync-on-video
(bi-level or tri-level sync)
Two digital audio outputs
One Digital Optical output
One Digital Coaxial output
Controls
Infrared remote control with direct access codes or manual controls on front panel
Functions accessible via either On Screen Display (OSD) or front-panel LED display
Fully programmable controls for each separate video input with non-volatile memories:
Automatic input source detection & input priority selection
Input aspect ratio select: 4:3 fullframe, 4:3 letterbox, 16:9 fullframe or custom input aspect ratio
Output aspect ratio select: 4:3, 16:9 or custom output aspect ratio
Flexible horizontol and vertical Zooming & Panning controls
Picture controls with memory for each input: Brightness, Contrast, Saturation, Hue, Y/C Delay, Sharpness
Output Controls: Analog/Digital, Format/Resolution, Aspect Ratio, Sync Type, Colorspace (RGB or YPbPr),
Frame Lock, Display Profile
RS-232 automation/control interface with upgradeable software for "future-proof design"
Built-in test patterns for ease of set up
Power
Universal AC mains input: 100 - 240 VAC @ 50 - 60 Hz
Consumption < 30W
Sleep mode - automatic 30 second timeout indicated by power indicator color change
Physical
Dimensions 10.4" x 17"x 2.2" (26.3cm x 43.3cm x 5.5cm) with desktop feet
Standard 19" 1U 1.75" rackmount option
Weight
Shipping - 10.5 lb (4.8 kg)
Unit (without power supply) - 6.4 lb (2.9 kg)
Edited by - armani on 2004/06/17 13:52:17
