 Arcam-system - **SÅLD**
harley
Posted - 2004/05/31 :  11:16:09  Show Profile Send harley a Private Message
Arcam-system
Arcam A80 integrerad förstärkare, nypris 9.895:-
Arcam CD82T cd-spelare, nypris 9.995:-
Arcam P80 effektförstärkare (för biamping) nypris 7.400:-
Summa nypris: 27.290:-
Köpt jan-febr 2004
cirka 18 månaders garanti kvar!!!
Hela systemet i mattsvart läcker design!
Givetvis finns alla tillbehör samt packmaterial
samt kvitto och garantisedel.
Säljes p g a uppgradering.
A80 förstärkare 6.500:-
http://www.arcam.co.uk/diva/hifi/a80.html
CD 82T 6.500:-
http://www.arcam.co.uk/diva/hifi/cd82.html
P80 slutsteg 4.000:-
http://www.arcam.co.uk/diva/hifi/power_amps.html
Bi-amplification is simply using separate amplifier channels for each speaker driver, so that the bass and treble units are individually driven. The improvement in definition and control can be dramatic. All Arcam integrated amplifiers built since about 1997 have pre-amp outputs and use identical gain levels, so you can be sure of perfectly matched results when bi-amping with Arcam amplification.
Edited by - harley on 2004/07/12 10:33:17
Halen
Posted - 2004/06/08 :  21:22:07  Show Profile Send Halen a Private Message
Vad blir det för nya grejer?
Var bor du?
Bobbokrull
f.d. "Robin Fischer"
Posted - 2004/07/12 :  12:12:59  Show Profile Send Bobbokrull a Private Message
Ett Bryston kanske??=)
