 Plinius SA-250Mk4 "Oanvänt i kartong"
Matte2003
Posted - 2004/04/30 :  12:43:20  Show Profile Send Matte2003 a Private Message
Plinius SA250 MkIV
Färg = Svart.
Nyinköpt i kartong och aldrig använt eller uppackat.
Inköpt för att användas i hembio men har gått
tillbaka till 2kanals stereo.
Omkopplingsbart att köra klass A eller AB med vippa på fronten.
Inklusive Garanti & Kvitto.
Info: www.pliniusaudio.com
Review:
http://www.pliniusaudio.com/lin/rev04.htm
http://www.audioreview.com/Amplifiers/Plinius/PRD_116088_1583crx.aspx
Spec:
Power: 250 Watts per channel into 8 Ohms, 450 Watts per channel into 4 Ohms. 900 Watts per channel into 8 Ohms in bridged and true balanced mono modes.
Frequency Response: DC to 70kHz @ -3dB.
Distortion: Typically < .05% THD at rated power into 8 Ohms.
Current Output: 70 Amps short duration continuous per channel. Fuse protected.
Hum & Noise: 100dB below rated output 20Hz to 20KHz.
Input Sensitivity: 1.2 Volts RMS at 1kHz for rated output.
Input Impedance: 47k Ohms
Dimensions: Height 275mm (10.75"), Width 510mm (20"), Depth 535mm (21"), Weight 57kg (125lb).
Input Options: RCA Stereo, RCA Bridged Mono, XLR Balanced Stereo, XLR Balanced Mono.
Nypris 65 000 Sek.
Säljes för 50 000Sek eller Seriösa Bud.
Kan användas som delbyte med Wadia 861 eller Wadia 861se eller Transport + DAC.
Edited by - Matte2003 on 2004/05/04 12:04:31
