 QLN 606
Hanmol
Posted - 2004/04/27 :  20:33:33  Show Profile Send Hanmol a Private Message
QLN 606
QLN 606
Qln 606 säljes. Utförande i bok. Mintcondition.
nypris 8000 kr på Tele-hå. Drygt ett år gamla.
Pris: 4800 ev billigare vi snabb affär
Features
* Floor standing 2,5-way reflex design.
* Reflex port with rounded edges and large area for
lower distortion.
* Heavy 8 mm spikes, 5 pcs of inserts for improved
stability and sound.
* High-efficiency 27 mm tweeter with coated silk fabric
dome and damped rear cavity.
* Absorbent felt on the tweeter for reduced reflection of
high frequencies.
* Twin 165 mm low-mid drivers, treated lightweight
fibre cone, improved large magnets system, non-
magnetic chassis.
* High-grade audio components in crossover for
perfect match to the drivers.
* Slim cabinet design for improved stereo image.
* Cabinet construction of 32 mm MDF and 22 mm high
density board, extensive internal bracing to eliminate
structural resonance and coloration.
* Sub-cavity for optional increase of mass damping.
* Bi-wiring option with 4 heavy gold plated connection
terminals.
* Optional finishes. Cherry, light rose and black.
Specifications
Principle: 2,5 way bass reflex floorstander
Woofer: 6 1/2" doped lightweight fibercone with large
high-flux magnet
Mid: 6 1/2" doped lightweight fibercone with large
high-flux magnet
Tweeter: 1" coated silk fabric dome, ferrofluid cooled
Impedance: 4 ohm
Power handling: 250 W
Sensitivity: 90 dB SPL 1 W, 1 m
Frequency response: 30 Hz - 22 kHz
Dimensions: 1050 x 210 x 430 mm
Weight: 22 Kg each (without mass damping)
Hanmol
Posted - 2004/04/28 :  12:03:50  Show Profile Send Hanmol a Private Message
upp
Hanmol
Posted - 2004/04/29 :  11:07:51  Show Profile Send Hanmol a Private Message
Bilder kan skickas också
