 REL Q200E *SÅLD*
Pjotre
dr. kursuppgång
Posted - 2004/03/22 :  18:43:57  Show Profile Send Pjotre a Private Message
Säljer min underbara REL subb. Den är svart. Här nedan är lite info om den som jag saxat in från REL:s hemsida:
True 200W (continuous) discrete direct-coupled MOSFET amplifier
Forward-firing 250mm (10”), long-throw, heavy–duty driver with 7.6 kg magnet and 4 layer edge-wound voice-coil
Refined ABC® infinitely variable crossover adjustment from 26 to 106 Hz
Four position mode selector: line/LFE (0 degrees phase and 180 degrees phase)
Audiophile grade toroidal transformer
Gas-tight Neutrik high level connection for long-term consistency of sound quality
High quality, panel-mounted twin phono inputs at 0dB and +12dB (low level)
Totally discrete input circuitry for high and low level inputs
Separate volume controls for high and low-level adjustment
Simultaneous connection of high and low level sources
Set-Safe® audibly transparent driver protection
Balanced-bridge power supply
4x ultra-rugged output devices
Double-sided glass-fibre board with plated-through holes
IEC power input socket - no captive leads for installation flexibility
Machined nylon feet
Hand-built in Great Britain, three year worldwide warranty
Specifications
System Type
Active ZeroQ Acoustic Suspension System with ABC®
variable bass filter. Closed box, 17 litre
Frequency Range
25Hz-100Hz
Amplifier Input impedance High level 100 Kohm : Low level 10 kohm
Gain Control Range
56dB
Drive unit impedance
4 ohm
Mains input voltage
115 V 50/60 Hz or 230 V 50/60 Hz, subject to country
Dimensions WxHxD mm (inches)
incl. feet and rear panel controls
300x328x353 (11.82 x 12.92 x 13.91)
Weight Kg (lbs)
17 (37.48)
Nypris är 11.000:- och jag vill ha 6.500:- för den.
Maila mig på min mailadress eller PM:a mig här.
Edited by - Pjotre on 2004/03/24 18:12:58
