 Bild på Regas nya arm -- RB700
mace
London calling
Posted - 2004/02/23 :  14:23:04  Show Profile Send mace a Private Message
All info från www.rega.co.uk
RB700
The RB700, improves greatly on the previous model, the RB600. The aluminium tube has been specially coated in a unique finish and the entire bearing housing has been redesigned and is now manufactured to even higher tolerances.
The tonearm tube itself (which is a one piece silicone/aluminium casting) is very rigid, whilst being low mass. The tonearm assembly is concentrated around precision, hardened stainless steel, miniature ball races of the highest quality. The bearings fit on to ground shafts and into the tonearm using interference fits. This means that no adhesive is required and therefore none of the associated (component - adhesive - component) losses in rigidity prevail. It is fitted to the plinth by a 3-point fixing which is CNC machined out of a single solid block of Stainless steel. This provides the strongest most rigid base structure possible for the tonearm and causes less stress on the plinth and the RB700's bearing housing, and therefore the least possible resonance.
The RB700 tonearm is designed to make cartridges work harder, maximising the cantilever acceleration and travel as much as possible with the utmost accuracy within the cartridge body thus providing new levels of information.
mera quad ESL = mera välljud.
Mr 500!
epkpeng
Posted - 2004/02/23 :  14:33:49  Show Profile  Visit epkpeng's Homepage Send epkpeng a Private Message
...till det facila priset av?
Vänligen
// Pär Engelholm
mace
London calling
Posted - 2004/02/23 :  15:06:33  Show Profile Send mace a Private Message
Svårt att hitta, men jag slår vad om en pilsner i Ängelholm i sommar att den hamnar på £700 +-10%
M
Mr 500!
Daniel
Posted - 2004/02/23 :  15:52:03  Show Profile Send Daniel a Private Message
Den ser ju riktigt trevlig ut. Undra om den ljudmässigt närmar sig rb-1000? Då lär den bli en succe.
bliss
Posted - 2004/02/23 :  16:22:40  Show Profile Send bliss a Private Message
priset har jag inte hört något om, men på rega säger de att deras nya "tonearm 'RB700'; more inline with the RB1000 with apperance and engineering".
mace: jag fick se bilder på p5an och p7an på annat håll. tyvärr tyckte jag att p7an var grymt ful, men bilden kanske inte gjorde den rättvisa. såg ut som att power supplyen satt i regas riaa/hörlursförstärkarlåda. spänd på hur det kan låta dock.
bliss
Oh by the way, which one's Pink?
mace
London calling
Posted - 2004/02/23 :  17:26:44  Show Profile Send mace a Private Message
Jag har inte lyckats hitta några bilder på nätet
Den var nog rättvis Grymt är ordet Och ful är bara början
Tur att smaken är olika, så att de får några sålda
Lådan såg ut som ett mellanting mellan RIIA lådan och en hammond låda
M
Mr 500!
Daniel
Posted - 2004/02/23 :  17:30:41  Show Profile Send Daniel a Private Message
Var har ni sett bilder på den då?
Posted - 2004/02/23 :  17:55:38  Show Profile Send Bubbel a Private Message
Sådan kan man snickra ihop hemma särskilt då den biten med hög precision är enkel att svänga till.
/Anders
bliss
Posted - 2004/02/23 :  17:59:28  Show Profile Send bliss a Private Message
ja här har jag sett några bilder iaf http://63.99.108.232/forum/showthread.php?s=&postid=26519#post26519
bliss
Daniel
Posted - 2004/02/23 :  22:13:09  Show Profile Send Daniel a Private Message
Tack för det Bliss. Kan bara hålla med, den ser ganska märklig ut. Men armen är snygg.
