 Cardas Golden Ref 1,5m xlr SÅLD!
Rydberg
Posted - 2004/02/17 :  13:15:24  Show Profile Send Rydberg a Private Message
Highendkabel och Cardas bästa. Mycket bra kabel, detaljerat men ändå lungt ljud. Säljes pga att jag för många kablar just nu. Glöm utseendet, denna är bra, mycket bra!
Nypris: 15397:- Nu: 5000!
Kan skickas!!
Had the Cardas Cross interconnects for over 6 months. Got the Golden Ref from my dealer as demo, running from the CJ PV14 preamp to the CJ MV60 amp, and heard the difference right away. Better bass, better definition, and all the good qualities as reviewed by others below.
Wife was away for a week when the change happened. She heard the improvement right away - and started looking for what I did to the system!
Expensive but worth every dollar for the improvement in sound! Thumbs up to George for an excellent product.
http://ecoustics.consumerreview.com/pscAudioReview/Cables/Cables/Golden,Reference/PRD_116413_1584crx.aspx
Edited by - Rydberg on 2004/10/21 18:59:36
Bubben
Posted - 2004/03/08 :  23:04:34  Show Profile Send Bubben a Private Message
Den ser ju bättre ut än NO i alla fall, även om den inte når upp till Air3.
Skämt åsido, Hur låter den..eller inte låter...?
Rydberg
Posted - 2004/03/09 :  02:24:23  Show Profile Send Rydberg a Private Message
Lugnt, detaljerat och avspännt! En kabel som vinner i längden!
Edited by - Rydberg on 2004/04/07 19:04:25
Mahler
Posted - 2004/06/30 :  13:51:17  Show Profile Send Mahler a Private Message
Prisidé??
Tabula Rasa!
Rydberg
Posted - 2004/06/30 :  14:41:05  Show Profile Send Rydberg a Private Message
Mahler du har PM
Mahler
Posted - 2004/06/30 :  16:03:05  Show Profile Send Mahler a Private Message
Rydberg DU har PM
Tabula Rasa!
