 13m8640-00
mauro d.
Posted - 2004/01/29 :  22:54:12  Show Profile Send mauro d. a Private Message
what do you think about the 13m8640-00 ?
and in comparison with d52 ?
thank you in advance
mace
London calling
Posted - 2004/01/30 :  00:58:33  Show Profile Send mace a Private Message
and
M
mera quad ESL = mera välljud.
Mr 500!
mauro d.
Posted - 2004/01/30 :  15:05:09  Show Profile Send mauro d. a Private Message
i don't understand!
what are you saing?
x8668k
Posted - 2004/01/30 :  15:08:47  Show Profile  Visit x8668k's Homepage Send x8668k a Private Message
That is what he is saying, what it means on the other hand...
Guldfiskminne...
Posted - 2004/01/30 :  15:17:33  Show Profile  Visit Zalve's Homepage Send Zalve a Private Message
What is "13m8640-00" and "d52" ? Some sort of circuit ?
Che cosa è "13m8640-00" e "d52"? Una certa specie del circuito?
Se provate a spiegare un po'di più. Che cosa state provando a costruire con "13m8640-00"?
Jag bad honom förklara vad han skulle bygga med dem...
x8668k
Posted - 2004/01/30 :  15:28:21  Show Profile  Visit x8668k's Homepage Send x8668k a Private Message
Ja, Italienska är inte min starka sida precis...
Låter inte som nån förstärkare jag känner igen iaf, eller CD, eller, så det kan ju vara det du skrev.
Guldfiskminne...
DIYamps
Ej medlem längre
Posted - 2004/01/30 :  15:28:39  Show Profile Send DIYamps a Private Message
zalve: hur många språk kan du??? du verkar kunna en del.
x8668k
Posted - 2004/01/30 :  15:30:15  Show Profile  Visit x8668k's Homepage Send x8668k a Private Message
SCAN-SPEAK 2.5" CONE MIDRANGE
Excellent driver with extended frequency range and wide dispersion. Symmetric Drive magnet system with a light paper cone, coated for optimum damping of resonances. Low loss rubber surround ensures high resolution combined with very low and controlled distortion figures. Textile dome, coated dust cap. The sound is detailed and clean and has a very natural balance. Best Xover 300Hz+.
Pwr 100Wrms (@300Hz)
Sd 48cm²
Coil 38mmØ (0.10mH)
Re 8W (5.8Wdc)
Fr 64Hz(Fs)®8KHz
Sens’ 87.5dB
Qms 2.70
Qes 0.27
Qts 0.24
Vas 5.00L
Code 13M8640-00
Guldfiskminne...
Audio Nicke
Posted - 2004/01/30 :  15:43:32  Show Profile Send Audio Nicke a Private Message
You probably mean to ask our advice about Middrange speakers.
Is it possebly the scanspeak 13m8640 and the Dynaudio d52?
If this is your question you have to give us a little more info.
What tweeter are you thinking about using?
What bas?
And ofcourse give us some sort of idea what kind of result your hoping for.
Then we can perhaps help you some more.
/N
Stavar som en kratta bara så ni vet;-))
/Nicke
Posted - 2004/01/30 :  16:19:17  Show Profile  Visit Zalve's Homepage Send Zalve a Private Message
Snyggt jobbat grabbar att hitta beteckningarna. Nu till Italienska
x8668k ha scritto:
Driver eccellente di MEDIA SCADENZA del CONO di SCAN-SPEAK 2.5"con la gamma di frequenza estesa e la dispersione larga. Sistema simmetrico del magnete dell'azionamento con un cono di carta chiaro, ricoperto per inumidirsi ottimale delle risonanze. La gomma bassa di perdita circonda accerta l'alta risoluzione unita con le figure molto basse e controllate di distorsione. Cupola della tessile, cappuccio parapolvere rivestito. Il suono è dettagliato e pulito ed ha un equilibrio molto naturale. Xover Migliore 300Hz+.
Sd 48cm²
Coil 38mmØ (0.10mH)
Re 8W (5.8Wdc)
Fr 64Hz(Fs)®8KHz
Sens’ 87.5dB
Qms 2.70
Qes 0.27
Qts 0.24
Vas 5.00L
Code 13M8640-00
Nicke audio ha scritto: Voi probabilmente medi per interrogare il nostro consiglio riguardo agli altoparlanti di Middrange. È possebly lo scanspeak 13m8640 ed il Dynaudio d52? Se questa è la vostra domanda dovete darci un poco più Info. Che tweeter state pensando a usando? Che bas? Ed il ofcourse ci dà una certa specie dell'idea che genere di risultato la vostra speranza per. Allora possiamo forse aiutarli un po'di più.
Grabbar... Kom ihåg att det alltid finns nån som kan... I detta fall http://babelfish.altavista.com/babelfish/tr
Mauro d. Usi questo luogo a transate il vostro italiano a http://babelfish.altavista.com/babelfish/tr inglese
molsson
Posted - 2004/01/30 :  16:34:18  Show Profile Send molsson a Private Message
babelfish. hahaha. Hoppas att det blev begripligt. Det brukar bli helt hysterisk meningsbyggnad.
No hay banda!!
Jesper_Nilsson
Posted - 2004/01/30 :  17:01:25  Show Profile Send Jesper_Nilsson a Private Message
I have no experiece with the dynaudio driver but the 13M8640 is a very nice driver. It have some serious breakup at 10Khz, and a 3db bump at about 2k. The 3db bump is not a big consern but I guess it should be removed for best result. I've used it together with a 9300 tweeter crossed at 3k 2:nd order and no notch filter (for the 3db bump) with very good result.
/Jesper
mauro d.
Posted - 2004/01/30 :  21:14:46  Show Profile Send mauro d. a Private Message
hey people !
thanks a lot for your answer.
now more detailed notice:
i mount per speaker two 21w8555-01,two 18w8545-00,one mid dome ,and one mdt33.
- 21w8555-01 scan-speak woofer;
- 18w8545-00 scan-speak mid woofer;
- 13m8640-00 scan-speak mid cone;(comparison with d52af)
- mdt33 morel triple magnet sistem tweeter (home components).
the mid must work from 1khz ti 2khz,which is the better between scan and dynaudio?
these are the componets i use in detail.
Posted - 2004/01/30 :  23:03:00  Show Profile  Visit Zalve's Homepage Send Zalve a Private Message
Do you want help with the cross-over parts or just our opinion about your plans ?!
Posted - 2004/01/30 :  23:16:54  Show Profile Send jonasz a Private Message
I think he means wich of the mids that will work best in this application 1-2 khz. I really have no idea myself but I guess d52af have higher sensitivity while the 8640 can be crossed lower. I would use the d52 because of the sensitivity and you don't have to use a low crossoverpoint.
Cheers
