 Martin Logan Quest Z *Prissänkt 5000 kr*
popalex
Posted - 2004/01/02 :  10:57:41  Show Profile  Visit popalex's Homepage Send popalex a Private Message
Världens bästa högtalare?
Låter fantastiskt!!
Mycket fint skick!
Tekniska specifikationer:
  • System Frequency Response: 28 - 24 000 Hz +/-2db
  • Electrostatic Frequency Response: 100 - 24 000 Hz +/-2db
  • Woofer Frequency Response: 28 - 2 000 Hz +/-2db
  • Woofer Speed: @ 50 Hz: 6.3ms (capable of 160 Hz) @ 100 Hz: 1.2 ms (capable of 830 Hz)
  • Presence Control Switch: +2dB from 1 000 - 5 000 Hz
  • Bass Control Switch: -3dB from 60 - 150 Hz
  • Crossover Frequency: 125 Hz at 12dB per octave
  • Dispersion: Horizontal - 30 Degrees Vertical - 4' Line Source
  • Sensitivity: 90dB/1 watt/meter
  • Power Handling: 200 Watts per channel
  • Recommended Amplifier Power: 80 - 200 Watts per channel
  • Impedance: Nominal: 8 Ohms Minimum: 2 Ohms
  • Phase Angle: Less than 45 degrees
  • Weight: 56 kg each
  • Size (HWD): 185cm x 48cm x 33cm
  • Components: Custom wound audio transformers polypropylene bypass caps 100% OFC coils
Nypris ca 70 000 kr
Säljes pga platsbrist för endast 30 000 kr!
Finns i Stockholm.
Ring gärna på 070-7338337
Edited by - popalex on 2004/01/12 08:19:37
popalex
Posted - 2004/01/07 :  09:44:16  Show Profile  Visit popalex's Homepage Send popalex a Private Message
Upp i listan
popalex
Posted - 2004/01/09 :  08:54:13  Show Profile  Visit popalex's Homepage Send popalex a Private Message
upp
popalex
Posted - 2004/01/12 :  08:19:48  Show Profile  Visit popalex's Homepage Send popalex a Private Message
upp
popalex
Posted - 2004/01/15 :  09:27:06  Show Profile  Visit popalex's Homepage Send popalex a Private Message
upp i listan
popalex
Posted - 2004/01/26 :  08:18:41  Show Profile  Visit popalex's Homepage Send popalex a Private Message
upp
popalex
Posted - 2004/02/16 :  11:00:24  Show Profile  Visit popalex's Homepage Send popalex a Private Message
upp
