 CD, SACD, DVD-Audio......Ähhh, Kolla HÄÄÄR!
mace
London calling
Posted - 2003/11/13 :  22:49:04  Show Profile Send mace a Private Message
Alla moderna ljudalternativ med frekvensomfång bredare än vinergatan och bitrates högre än solens kärntemperatur ! SicketTJAFS !
Köpte ett gäng skivor idag, riktiga skivor alltså, inga små whiskyglas-brickor.
Nedplitat från baksidan av det stadiga 12" fodralet (konvulutet?)
Here it goes
''GUARANTEED HIGH FIDELITY IN ''360'' HEMISPHERIC SOUND
ANOTHER COLUMBIA FIRST - GUARANTEED HIGH FIDELITY.
The symbol ''360'' SOUND is the summa cum laude of high fidelity.
It is Your GUARANTEE that each record so designated has been engineered and induvidually tested under the supervision of the Columbia Sound Laboratory.
Starting with the taping of the performance, through strategically placed wide-range microphones, EVERY step in the manufacturing process is checked for peak efficiency--including an actual laboratory-calibrated playback of EACH disk before it is released.
Not only original masters, but stamper test-pressings are required to match, in A-B tests, the tapes from which they were derived.
Only such rigid control permits production of recordings covering the entire 30 to 15,000 cycle range within a plus or minus 2-decibel tolerance.
Like the 360 degrees of a perfect circle, ''360''SOUND is the true spectrum of high fidelity.
For this reason Columbia Records, The oldest name in recording and creator of ''Lp'', GUARANTEES without reservation the fidelity of this ''360''SOUND record.
Ord och inga visor !
Fattar inte varför folk fortsatte att forska & exprimentera inom Hi-Fi området?
M
mera quad ESL = mera välljud.
Mr 500!
MaxMartin
Posted - 2003/11/13 :  22:58:08  Show Profile Send MaxMartin a Private Message
Bravo
Posted - 2003/11/13 :  23:16:26  Show Profile Send Bravo a Private Message
De skulle nog behöva ha samma inställning idag.
Högsta noggranhet och strategiskt placerade mikrofoner var det ja.....
Bravo
Per Berger
Posted - 2003/11/14 :  11:10:55  Show Profile  Visit Per Berger's Homepage Send Per Berger a Private Message
Och hur lät det?
/P
Pass
Posted - 2003/11/14 :  14:03:41  Show Profile Send Pass a Private Message
Och jag som trodde att "perfect sound forever" var en slogan för CD mediet;-)
Det finns inga genvägar...
