 Roksan Caspian M
Klenkar
Posted - 2003/10/10 :  14:44:01  Show Profile Send Klenkar a Private Message
Helt "ny" serie från Roksan!
mvh dd
The new look Caspian Integrated Amplifier benefits from many superior quality components providing wider bandwidth, lower distortion and more dynamic range for enhanced performance. Improved ventilation for cooler running allows longer periods of increased sound level before thermal protection cut out point. Its new higher power output devices, high specification coupling capacitors, signal and driver transistors and improved power supply provide a deeper and tighter bass, more open mid range and smoother more detailed top end and better control over the loudspeakers than its predecessor. All this combined with precise timing and enhanced sound staging has redefined the performance of this world wide acclaimed amplifier. With its new classic and timeless aesthetics the Caspian MSERIES-1is an integrated amplifier in a class of its own.
Line Inputs 5 plus Tape
Input Impedance 47 kW
Input Sensitivity (70W) Line 240mV
Line Outputs Tape, Preamplifier (x2)
Output Voltage 240mV (Tape Out)
700mV (Pre Out)
Power Outputs Loudspeaker, L & R
Output Power >85 Watts, into 8W
both channels driven
>120 Watts, into 4W
Power Supply 350VA Ultra Low Noise Toroidal Transformer
4 Regulated Supply Rails
Current Output 50 Amps Peak to Peak
Damping Factor 140 (8W)
Frequency response -3dB, <1Hz – 90kHz
Gain 40dB Overall (Pre & Power)
9.3dB Preamplifier
30.7dB Power Amplifier
Harmonic Distortion 0.002% 1kHz, 0.015% 20kHz 10W - 8W
0.0025% 1kHz, 0.03% 20kHz 50W - 8W
Signal to Noise Ratio Line 108dBa (ref. 500mV)
85dBa (ref. 1W, 8W)
Power Source 100V – 120V 50Hz / 60Hz
220V – 240V 50Hz / 60Hz
(via Mains inlet filter)
Power Consumption < 230 W
Dimension 432 x 330 x 70 (W x D x H) mm
432 x 330 x 80 (including feet)
Weight 12Kg
The new look Caspian Integrated CD Player utilises many superior quality components and all new double sided 2 oz copper D/A and Mother board. To enhance performance, all the power supplies and their components feeding the digital and analogue circuits have been up rated for lower distortion, lower noise and more dynamic range. Increased ventilation for cooler running and modified power supply to the display has ensured much improved longevity. The servo circuit for the laser has been improved for better performance and playability of difficult to read CD-R discs. Thanks to improved power supplies, high specification coupling capacitors, super precision master clock and new D/A and Mother board the new Caspian has tighter and better defined bass, more open and detailed the mid range with an extended yet smoother top end.
These improvements ensure better timing, dynamics and sound staging that compliment the new Caspian range. The classic, timeless aesthetics of the Caspian MSERIES-1coupled with superb audio performance make this integrated CD player a must for any high-end system.
Operating System CD digital audio system
Frequency Response 20Hz – 20kHz ± 0.3dB
Harmonic Distortion 0.002% @ 1kHz
S/N Ratio (IHF-A Wtd.) 105 dB
Wow & Flutter Quartz precision
Channel Separation 100 dB @ 1kHz
Output Voltage 2Vrms
Digital Output BNC 75W 0.5 Vp-p
Error Correction CIRC
Sampling Frequency 44.1 kHz
D/A Conversion Dedicated D/A PCB (TD1305T BCC-DAC2)
(Bitstream continuous calibration DAC)
Resolution 18 bits
Oscillation 3rd Overtone Oscillation
Crystal Super precision, custom made
Power Supply High quality mains inlet filter
2 high performance low noise toroidal transformers
One dedicated to the DAC analogue output stage
One dedicated to the Digital circuitry
7 fully regulated power rails
Power Consumption < 15 W
Weight 10Kg
...at the gates of hell I will swing my sword, converting the souls of the non-believers...
Edited by - Klenkar on 2003/10/28 14:15:08
Jonas Nilsson
Posted - 2003/10/10 :  15:25:16  Show Profile Send Jonas Nilsson a Private Message
Länkarna funkar inte
Får någon "server login" ruta......
Klenkar
Posted - 2003/10/10 :  20:13:55  Show Profile Send Klenkar a Private Message
Skit!
Snutten
Posted - 2003/10/10 :  21:09:52  Show Profile Send Snutten a Private Message
Har lyssnat lite på den, ser snyggare ut än den gamla tycker jag men den är nog förövrigt väldigt lik den gamla ljudmässigt. Ett bra förstärkarval i prisklassen.
stargazer
Posted - 2003/10/27 :  08:57:35  Show Profile Send stargazer a Private Message
Hallå - bilder, info? Pleaaase...
(inget finns på officiella webben http://www.roksan.co.uk)
/ Stargazer, nybliven roksan-fan
wallraff
Posted - 2003/10/27 :  11:42:00  Show Profile Send wallraff a Private Message
Snackade med en kille från Hifi Art på malmömässan, han sa att caspian m är ersättare till vanliga caspian. Ser nästan likadana ut, lite andra "rattar". Skulle nog vara lite mer effekt men vara nästan identiska i ljudet. Helt enkelt bara lite bättre :-)
Almost Famous
Klenkar
Posted - 2003/10/27 :  18:23:56  Show Profile Send Klenkar a Private Message
20% mer för att vara lite mer exakt.
dd
Bravo
Posted - 2003/10/28 :  02:47:07  Show Profile Send Bravo a Private Message
Är det någon prisskillnad?
Bravo
MartinH
Audiotrade
Posted - 2003/10/28 :  08:59:52  Show Profile Send MartinH a Private Message
Den nya M-serie förstärkaren ligger på 1000:- mer än den gamla, vad som hänt är en kosmetisk uppgradering som många så på mässan, samt en del uppgraderingar inuti. Nytt kretskort och bättre strömförsörjning, uppfrächning av en del viktiga komponenter har oxå skett. Effekten har gått upp från 70 till 85 watt.
Ljudmässigt ska den bli bättre i basen och få ett mer luftigt och mer balanserat ljud. Inga stora förändringar, men varför ändra på ett vinnande koncept ?!?
/martin
Aton
Posted - 2003/10/29 :  18:46:53  Show Profile Send Aton a Private Message
En bild säger mer än tusen ord. (Kanske inte var rätt ordspråk på ett hififorum...) Men en bild är hursomhelst aldrig fel.
Klenkar
Posted - 2003/10/30 :  11:22:35  Show Profile Send Klenkar a Private Message
Martin H borde väl kunna fixa lite bilder!!!!
Martin kom igen nu!!!!
MartinH
Audiotrade
Posted - 2003/10/30 :  16:37:53  Show Profile Send MartinH a Private Message
Jo jag ska se till at få ut nått till helgen....
MartinH
Audiotrade
Posted - 2003/11/05 :  22:53:22  Show Profile Send MartinH a Private Message
Nu har jag en bild på den "nya" integrerade Caspian förstärkaren... Det är inte jag som tagit den utan en besökare på Malmömässan där vi visade den ( Foto av Nagref & Ranefjrod )...
poman
Posted - 2003/11/06 :  15:54:23  Show Profile Send poman a Private Message
Den var väldans snygg förmodligen också mycket välljudande har tyvärr
aldrig lyssnat på någon skulle annars varit intressant någon gång.
MartinH
Audiotrade
Posted - 2003/11/06 :  21:55:23  Show Profile Send MartinH a Private Message
Pris på den nya Caspian är 13900:-, så den har bara gått upp ca 1000:- från den gamla.. Och ljudmässigt har den blivit renare och fått en mer kontrolerad och fast bas, ljudbilden har vuxit lite och fått ett mer lyster om sig. Effekten har gått upp från 70 till 85 watt...
Så en redan prisvärd och trevlig förstärkare har nu blivit ännu intressantare...
/Martin
Mr Ekan
Posted - 2003/11/06 :  22:44:44  Show Profile Send Mr Ekan a Private Message
Ser mumma ut. Vore kul att jämföra mot Rega Mira 3...
Erik Andersson for president!
MartinH
Audiotrade
Posted - 2003/11/07 :  11:17:29  Show Profile Send MartinH a Private Message
Jag har gjort det !! Men jag är lite jävig i mina åsikter iof så jag ska nog inte säga för mycket i frågan...
/Martin
Jonas
Posted - 2003/11/07 :  13:11:28  Show Profile Send Jonas a Private Message
Wow, den såg fin ut... Har lust att byta ut mina svarta (iochförsig också snygga) Thule prylar mot något i silver. Mest för bytandets skull. Nån som har en bild på den gamla Caspian?
"My head kissed the ground, I was half the way down"
Mina system
MartinH
Audiotrade
Posted - 2003/11/07 :  14:03:42  Show Profile Send MartinH a Private Message
Larsho
Posted - 2003/11/07 :  14:08:26  Show Profile Send Larsho a Private Message
Ett klart lyft jämfört med den gamla modellen
stargazer
Posted - 2003/11/07 :  14:14:37  Show Profile Send stargazer a Private Message
Tänk vad lite färg på några plastknappar kan göra...
Skillnaden är väl inte så rasande stor, visst är det snyggare med runda former på de två "stora" rattarna (inga associationer nu, tack).
Men även den gamla (som jag nyligen köpt demoex av) är väldigt snygg, tycker jag (den gör sig inte riktigt på bild IMHO)
Men det viktigaste är att Caspian är en gröndj*#¤lskt bra förstärkare, särskilt m.a.p. priset.
Kommer även Roksan Caspian Power Amplifier (fyndigt namn, INTE ) i ny version?
/ stargazer, nybliven Roksan-entusiast
Klenkar
Posted - 2003/11/07 :  15:00:57  Show Profile Send Klenkar a Private Message
Min caspian har inga plastknappar. Aluminium
Sedermera så tycker jag att de fallit in konformismsspåret. Den gamle har mer av vad jag skulle kalla egenkaraktär. Se plastig ut! Hoppas att det inte är plast knappar bara Mr Touraj har smällt dit.
MartinH
Audiotrade
Posted - 2003/11/07 :  15:09:53  Show Profile Send MartinH a Private Message
Nej det är inte plastknappar... Och det är tänkt att alla produkter i caspian serien ska uppdateras till den nya locken och få sig en genomarbetning inuti. Ljudmässigt så är det skillnader men inte några massiva saker ( den har ju faktiskt inte gått upp så mycket ), ser man på cdn så har kontakterna blivit klart bättre och även hela mekaniken är omarbetad till det stabilare hållet...
Sen är ju alltid det där med design nått som är individuelt, men det finns säkert en förklaring till at man valt att gå med en lite mer silvrig karaktär på den nya serien.. Det ska bli kul och se hur den nya toppserien som kommer i början av nästa år kommer att se ut...*spännande*
/Martin
Klenkar
Posted - 2003/11/07 :  15:19:16  Show Profile Send Klenkar a Private Message
Martin, har du sett de nya monoblocken och förförstärkaren?
Hur kommer de att ligga effekt och prismässigt?
Kommer nog att konkurrera lite med MOON's prylar!
MartinH
Audiotrade
Posted - 2003/11/07 :  15:38:12  Show Profile Send MartinH a Private Message
Näe jag har tyvärr inte det... När jag var över hos Roksan i maj i år så ville man inte visa nått för oss ( hemligt !! ) Men priserna chansar jag kommer ligga i lägre MOON klass, men vi får se..
Men det kommer monoblock och försteg i caspianserien vad jag har för mig.. Men dessa vet jag inte riktigt när de kommer. Men de som jag tänker på är en helt ny serie som ska motsvara den gamla ROK-serien som man hadde...
Sen rycktas det om en ny högtalare snart oxå...
/Martin
Larsho
Posted - 2003/11/07 :  18:36:04  Show Profile Send Larsho a Private Message
Tycker det är stor skillnad mot förra modellen till
det bättre, ser inte ett dugg plastigt ut
