 Ekvivalent till 6N1P
Rydberg
Posted - 2003/10/08 :  20:50:19  Show Profile Send Rydberg a Private Message
6N1P som sitter i ARC VS55, finns det någon europeisk ekvivalent som skulle funka i detta steg?
Edited by - Rydberg on 2003/10/10 01:40:06
Dimitri
Posted - 2003/10/08 :  21:00:49  Show Profile Send Dimitri a Private Message
Equivalent to 6DJ8, ECC88 and 6922
Dimitri
Rydberg
Posted - 2003/10/08 :  21:05:31  Show Profile Send Rydberg a Private Message
Har läst det också, men är den det, har ju inte samma spec. Nån annan som vet mer.
Edited by - Rydberg on 2003/10/08 21:06:02
Rydberg
Posted - 2003/10/08 :  21:09:51  Show Profile Send Rydberg a Private Message
Hittade detta:
The 6N1P is basically an up-rated 6DJ8/ECC88 tube built in Russia. It has a higher heater current and plate watt rating than the 6DJ8. It is a good tube.
I have not had the chance to check the plate dissipation Ron is running the 6N1P in his DRD amp, but if you are wanting to run a 6DJ8 make sure it will be in specs, or adjust it accordingly. Given the nature of the circuit, you may or may not get that much benefit from running expensive NOS tubes in this position.
As for the other types "(ECC81, 82 or 83)", no. These are different animals. If you would like to redesign the amp to work with them, you could probably do it. They are not plug in compatible in this design. People sub these tubes in guitar amps because they dig the distortion.
Dimitri
Posted - 2003/10/08 :  21:24:48  Show Profile Send Dimitri a Private Message
Hifi World diy supplement från april 1995.
Det finns flera ekvivalenter. 6922, militärspecade 7308 osv. Mkt populärt rör.
Men ett av de mest mikrofoniska rören...
Dimitri
Rydberg
Posted - 2003/10/08 :  21:41:38  Show Profile Send Rydberg a Private Message
Aha, så du menar att det skulle funka att byta ut rören i ARC:en mot E88CC?
Dimitri
Posted - 2003/10/08 :  21:57:28  Show Profile Send Dimitri a Private Message
Menar och menar....
Ingen egen erfarenhet.
Men det verkar så. Onekligen.
Men: vill du vara 100% så har du rätt; Någon med riktiga kunskaper får säga sitt. Kanske i forumet jag gav dig länk till?
Dimitri
Rydberg
Posted - 2003/10/08 :  22:00:38  Show Profile Send Rydberg a Private Message
Oki, tack så mycket för hjälpen sålänge.
Rydberg
Posted - 2003/10/10 :  01:38:53  Show Profile Send Rydberg a Private Message
Nån som vet mer?
Posted - 2003/10/10 :  18:29:52  Show Profile  Visit Bernt Jansson's Homepage Send Bernt Jansson a Private Message
Det borde gå att sätta i E88CC i stället för 6N1P Men inte ECC88 utan vidare för det har max anodspänning 130V. 6N1P har max anodspänning 250V.
Förstärkningen är ungefär densamma. Du skulle kunna byta från ECC88 till 6N1P om glöden klarar det.
http://www.svetlana.com/graphics/products/pdf/6N1Pspec.pdf
http://www.mif.pg.gda.pl/homepages/frank/sheets/009/e/E88CC.pdf
