 Sennheiser, Cluo cable & MF X-can v2 +1200 *SÅLD*
cave
Posted - 2003/10/06 :  22:58:14  Show Profile Send cave a Private Message
Lägger in min annons på nytt
Sennheiser HD-600 i mintskick. 1500.- (nypris 3000.-)
http://www.lefflershifi.com/Library/Products/Sennheiser/HD600.htm
Cluo-cable 212 Red Jaspis earphone 500.- (nypris 1300.-)
Silver-plated copper-conductors insulated with Teflon as used in Krysolit.
Copper with a higher purity than 99,97%
Silver with a higher purity than 99,99%
Twined Clou-style
Shielded with three shields (Red Jaspis)
Goldplated 6,3mm plugs from Monacor and original Sennheiser by the earphones guarantee a good connection
Wondersold silver-solder from Audioquest used in all soldering
Duo Tech Corps CE 1000 Cable Inhancer used to run in all cables 100 hours to give you value for your money right away.
Musical Fidelity X-can v2 2300.- (nypris 3500.-)
Inkl. Adapter med mer krydda i, vilket ger ett mer precist och fastare
ljud.
http://www.lefflershifi.com/Library/Products/Musicalfidelity/X-CANv2.htm
Allt för 4000.- eller ge mig bud!
Edited by - cave on 2003/12/05 18:58:24
Tomas
Posted - 2003/10/07 :  10:58:36  Show Profile Send Tomas a Private Message
Du har PM!
Markus
Posted - 2003/10/07 :  13:25:24  Show Profile Send Markus a Private Message
Hur lång är kabeln?
cave
Posted - 2003/10/07 :  19:33:23  Show Profile Send cave a Private Message
3 meter!
JPL
I have a girl
Posted - 2003/10/07 :  20:18:18  Show Profile Send JPL a Private Message
Var bor du någonstans ??
mvh Patrik...
cave
Posted - 2003/10/07 :  22:05:47  Show Profile Send cave a Private Message
I Helsingborg/Malmö!
Zamn
Posted - 2003/10/11 :  17:23:22  Show Profile Send Zamn a Private Message
Jag köper din hörlurskabel för 500 om den finns kvar.
Du har fått ett pm också!
Yamaha AS700 / Technics SL-P777 / Yamaha T-85 / Sony PS-1350 / Audio Pro Black Diamond / Carlsson OA 52.3
pt99jst
Posted - 2003/11/16 :  15:36:23  Show Profile Send pt99jst a Private Message
Har du din x-can kvar?
/Johan
