 Kef KHT 2005 biohögtalarsystem *Sålt!*
Hotspur
fd. Fridefors
Posted - 2003/06/16 :  10:28:44  Show Profile Send Hotspur a Private Message
"Fantastic performance; superb build and looks; affordable"
(What HiFi Five Stars June 2001).
"They look great...really good value for money" (T3 Five Stars Issue 55)
"Quite simply one of the best home cinema sub/sat systems we have heard"
(Home Entertainment Best Buy)
"Gobsmackingly good: this could be the best sub/sat system you can buy below £1000"
Powerful, easy to set-up and secrete and undeniably gorgeous to look at, the KHT2005 offers outstanding performance and value for money. The satellite speakers include built in shelf stands which double as wall brackets for easy fitting and the subwoofer can be tucked into a corner, out of the way, yet still fill the room with outstanding, tight bass.
Power handling : Satellites: 100 watts
Subwoofer : built-in 150 watt amplifier
Sensitivity : Satellites: 88dB, subwoofer n/a
Impedance : Satellites: 8 ohms, subwoofer n/a
Magnetically shielded? Yes - all satellites and subwoofer
HxWxD (mm) / Weight: Satellites : 198 x 130 x 150 / 2 kg
Subwoofer : 370 x 320 x 320 / 14kg
Frequency response : Satellites: 80-20,000 Hz
Subwoofer : 35-150 Hz
Biwireable? No
Connections : 4mm banana/binding posts
Bass port? Satellites : Front ported
Drivers: Satellites : 100mm "UniQ" array
Extra : Satellites built from cast aluminium cabinets
Originalemballage plus väggfästen ingår. Garanti kvar.
Pris: 6500:-!!!
Tel: 073-908 43 06
Edited by - Hotspur on 2003/06/19 13:35:23
Beerfrog
Posted - 2003/06/16 :  16:11:07  Show Profile Send Beerfrog a Private Message
Hmm, som sagt!
Kan vi göra ngn deal med min Majik i inbyte mot 530 & ägg?
Du har mail!
My Buriza is my precious...
