Hotspur
fd. Fridefors
23 Posts |
Posted - 2003/06/16 : 10:18:10
Key Features DVD Regions 1-6 PAL NTSC DVD, SACD, Video CD, CD, CD-R/RW Playback Dolby Digital DTS Output DCS 5.1ch Surround Precision Drive II Block Noise Reduction Twin Laser Optical Pick up Dynamic Tilt Compensation Component Video Output 50-disc Playback Memory
Video Playback: DVD Video, CD, Video CD, SVCD, DVD-R/RW (Video Format), DVD-RW (VR Format), CD-R/RW, SACD Video D/A Converter: 10bit / 27MHz Block Noise Reduction Digital Video Enhancer Video Equalizer (Preset only) Signal Format System: NTSC/PAL
Audio Audio D/A Converter: 24bit / 192kHz DTS Digital Output 96kHz/24bit Digital Output 5.1ch Analog Output (Dolby Digital, DTS, SACD) TV Virtual Surround (2ch): Dynamic, Wide, Night, Standard Normal Surround (5.1ch) Enhanced Surround (5.1ch) DCS (5.1ch): Virtual Multi Dimension, Virtual Multi Rear, Virtual Rear Shift
Output Terminals Component Video Out: 1 S-Video Output: 2 Composite Video Output: 2 Digital Audio Output: 2 (1 coaxial, 1 optical) 5.1ch Analog Audio Output: 1 Analog Stereo Output: 2
Convenience Quick Setup Control Menu(Magic Pad) 50-disc Playback Memory Instant Replay Smooth Scan Smooth Slow Frame by Frame Unlocked Serch Title/Chapter Viewer Strobe Playback Angle Viewer Custom Parental Control Sound Feedback Screen Saver Audio/Video Bit Rate Indicator Layer Indicator
General Power Requirements: 220-240V AC, 50/60 Hz Dimension (W x H x D): 430 x 74 x 256 mm Weight: 2.8 kg. Färg: Svart
Ägarrecensioner: http://www.reviewcentre.com/reviews1228.html  Ett år gammal, köpt på Lars Bengtsson Audio/Video. Kvitto/kartong. Pris: 2800:-!!! Telefon: 073-908 43 06
Edited by - Hotspur on 2003/06/17 18:39:11 |
