 "BFA-connectors"
HenkesHiFi
Posted - 2002/08/08 :  12:54:50  Show Profile Send HenkesHiFi a Private Message
Läste att Arcams stärkare använder BFA-connectors, vad är detta? Läste också att banankontakter inte fungerar med dem?
Tack på förhand,
Henke
markku
Posted - 2002/08/08 :  13:15:56  Show Profile Send markku a Private Message
Jag hittade en förklaring:
The BFA Loudspeaker Connector has been developed for use on quality hi-fi separates and loudspeakers.
The design came as a result of amendments to the European safety standard BS\EN600 65 for consumer electronics, which effectively bans the use of the 4mm 'banana' type plug commonly used for connecting loudspeakers to amplifiers. The reasoning behind the prohibition of cable-mounted 4mm (and smaller-sized) plugs is that they can be inserted into a European mains socket with possibly fatal consequences.
The solution is to use a large enough plug to make this occurrence impossible. The BFA connector comprises an insulated recessed 'female' plug and an insulated recessed 'male' socket and is designed to comply with relevant European and North American Safety Standards.
The BFA Connector evolved from a concept first developed by British electronics firm Arcam, and has been refined during extensive cross-industry co-operation in conjunction with European safety authorities. A number of key UK manufacturers are developing specific connector designs with the help of UK connector suppliers.
http://www.british-audio.org.uk/bfa_connector.html
Markku
< "Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world." - Albert Einstein >
HenkesHiFi
Posted - 2002/08/08 :  13:36:18  Show Profile Send HenkesHiFi a Private Message
TAckar...
Klanters
Posted - 2002/08/08 :  14:27:08  Show Profile Send Klanters a Private Message
Är det någon som har koll på den där EU-säkerhetsstandarden egentligen? Jag har fått uppfattningen att väldigt få tillverkare följer den. Visst kan man tycka att den är korkad i och för sig, men det i sig är ju inte en tillräckligt bra anledning att strunta i den.
Hur förhåller det sig egentligen? Är standarden inte bindande utan bara en rekommendation, eller har reglerna inte trätt i kraft ännu?
bernu
Posted - 2002/08/08 :  15:20:21  Show Profile Send bernu a Private Message
Var kan man köpa BFA kontakter? Jag har nyligen införskaffat en Linn Classik och skulle vilja köpa lite fler och evetuellet bättre BFA kontakter. Jag misstänker att tonläget i GBG har men han har ju semster tills nästa vecka... Finns dte någon i Halmstad kanske?
/Björn
n/a
deleted
Posted - 2002/08/08 :  23:21:15  Show Profile Send n/a a Private Message
Audioquest har en banankontakt som funkar både som banan och bfa kontakt. Silverpleterad dessutom:
//X-ray
"Jag håller inte med dig om det du säger, men jag skulle med
mitt liv försvara din rätt att säga det."
-Voltaire
Nagref
Posted - 2002/08/08 :  23:26:34  Show Profile Send Nagref a Private Message
Tja backar du inte för lite postorder så kan du beställa från Elfa.
www.elfa.se
-The world is my oyster...
yalpa
Posted - 2002/08/09 :  00:10:58  Show Profile Send yalpa a Private Message
bara ett jävla elende med alla olika kontakter, gör att det blir bara ännu svårare att jämföra apparater = tillverkarna kan ljuga mer om hur överlägsna deras prylar är...
hade classik själv, fick alltid dra med 6m K400 kabel om man skulle kunna koppla in den, kabeln väger mer än classiken
