 Världens stärsta maffigaste slutsteg
arcam
Posted - 2003/05/18 :  13:32:08  Show Profile Send arcam a Private Message
Ekman, det var en Mikael Bladelius konstruktion
den var på 2x300 w kostade 1500000:- mvh Arcam
n/a
deleted
Posted - 2003/05/18 :  13:41:08  Show Profile Send n/a a Private Message
Annars har vi ju dem här.
Marknadens mest brutala monoblock!
MartinH
Audiotrade
Posted - 2003/05/18 :  17:37:02  Show Profile Send MartinH a Private Message
Jänkarna kan det där med att bygga rörsteg...
- Completely dual mono design
- Massive high storage power supply
- 12 x KT88, 4 x 12AU7, 2 x 12AX7 tube complement
- User selectable triode/ultralinear output
- Output power: 225 WPC
- Balanced and RCA inputs
- Dimensions: 19" W x 24" D x 12" H
- Weight: 200 lbs
EAR
Posted - 2003/05/18 :  19:53:14  Show Profile Send EAR a Private Message
Vad sägs om 800 rörwatt
Och en vevis är aldrig fel
svejk
NA addikt
Posted - 2003/05/18 :  20:27:21  Show Profile Send svejk a Private Message
Ja hänger också på rörisarna 1250 watt DUUUUUGER
http://www.vtl.com/pages/reference.html
Svejk
Cyber
Posted - 2003/05/18 :  23:08:35  Show Profile Send Cyber a Private Message
De här monoblocken är ju riktigt feta....
Model NL Reference Features
Dual Chassis Monoblock design
with four 2000 VA Toroidal transformers (two per chassis)
Each transformer operates at 96% efficiency. Regulation equals 4%
Laser Source Front Panel Illumination (one per chassis).
True balanced circuit.
Dual toroid transformer-quad filar wound high nickel content core w/electrostatic shield power supply.
Potted transformers in magnetic stainlesss steel can.
Dual bridge rectification. Laser biased, all "n" channel bipolar output stage.
Specifications
Bias Circuit One 630 nm Bias Laser per channel
Output Circuit: 48 NPN Bipolar Transistors, 24 per channel
Power Supply Filtration: 280,000 µF: 14 x 10,000 µF per channel (uses capacitors superior to that used in the NL Signature One)
RMS Power Output: 800 Watts per channel @ 8 Ohms
1600 Watts per channel @ 4 Ohms
3200 Watts per channel @ 2 Ohms
Total Harmonic Distortion: <0.01%
Transient Intermodulation Distortion: <0.01%
Slew Rate: 120 Volts per microsecond
Bandwidth: 1Hz-150KHz , + 0 -2.5dB
Input Impedance: 30,000 Ohms
Input Type: RCA, XLR
Output Impedance: 0.013 Ohms
Constant Current Capability: >100 Amps, >50 per independent channel
Dimensions: 33" x 18" x 18" (HxWxD), 5" x 5" WxD at top
Weight: 440 (220 lbs each) [Shipping weight: 580 lbs crated]
ekman
Posted - 2003/05/19 :  01:28:00  Show Profile Send ekman a Private Message
så stor men bara 300w? =)
Alexi
Ute och cyklar...?
Posted - 2003/05/19 :  02:08:14  Show Profile  Visit Alexi's Homepage Send Alexi a Private Message
800W 8ohm står det ju tydligt!
Är inte utgångsimpedansen ,013ohm väldigt låg?
Vackra och annorlunda var dom iaf.
Driver forumet faktiskt.se
ekman
Posted - 2003/05/19 :  02:10:35  Show Profile Send ekman a Private Message
alexi om du menar mig så syftade jag på dom stora bladeliuslocke och inte dom i inlägget över mitt
Rebo
Posted - 2003/05/19 :  08:51:36  Show Profile Send Rebo a Private Message
Alexi: 0.013 ohm är en ganska låg, men inte onormal utimpedans
Jakob_S
Posted - 2003/05/21 :  13:40:12  Show Profile Send Jakob_S a Private Message
ekman, japp... de var specade till 300W i 8ohm... sen dubblerade de effekten allteftersom man halverade ohm-talet... ända ner till 0,1 ohm, har jag för mig. det var ju de stegen de körde qrs jupiter med på arken 98(?)
//jakob
martinsson
Posted - 2003/05/22 :  12:41:39  Show Profile  Visit martinsson's Homepage Send martinsson a Private Message
Ett mycket trevligt gäng :
Med mycket intressant teknik.
Och underbart ljud.
I mina öron.
marcus_ec
Posted - 2003/05/22 :  16:14:54  Show Profile Send marcus_ec a Private Message
PA?
lindvall
Posted - 2003/05/22 :  16:23:59  Show Profile Send lindvall a Private Message
GamuT kanske? Stort åbäke i alla fall...
hsivp
Gissa vad min förkortning betyder!
Posted - 2003/05/23 :  13:40:04  Show Profile  Visit hsivp's Homepage Send hsivp a Private Message
vill bara visa er den här länken... läg märke till "turbo bost"
http://cgi.audiogon.com/cgi-bin/cl.pl?ampstran&1057542596
Framsidan
Henrik A
Posted - 2003/05/23 :  14:40:02  Show Profile Send Henrik A a Private Message
Rotade bland mina bilder och hittade denna från HC på Bladelius Monster. Prodigy´n & Neptunusen står som storleksreferens. (Krellarna ser ur som leksaker, dyra leksaker brevid)
"Im a bassplayer. I like doing the same thing over and over again."
