 Idag fick jag två nya baselement hemlevererade
Page: of 3
Niklas Nord
Posted - 2003/04/26 :  13:20:43  Show Profile Send Niklas Nord a Private Message
Idag, två st JBL 2235 15" element!
Max Pwr. 300 wRMS
Magnet Wt. 80 oz.
Foam Surround
Net Weight 22 lbs.
Box 6cf, 44x17x18"
Box 12cf, 44x29x21" Cone 138 Sq.";0.09sq.M.
Eff/Max SPL 93/118db
Voice Coil: 4" vented
Inductance 1.2mH
F3: 33Hz Ripple -0.4db
F3: 23Hz Ripple -.04db Fs 20Hz; Vas 16cf; 453 1
Qt. 0.25; Qm. 2.5; Qe .2
Xmax 0.66"; 17mm
Impedance/Re 8/6 ohm
JBL does "wonders with organ, bass drum, thunder, synthesizer and cannon shots. Flat within 0.7dB from 55 to 17Hz, and only -3db at 15Hz. Constantly amazed as I hear additional bass I never suspected was present. Lowest organ, drum, and synthesizer tones are distinctly felt, in an almost unimaginable way, as well as heard.
"One can actually feel the spaceship departure on Time Warp (Telarc CD) as the floors rumble and vibrate. Not overpowering or tiring, as with some subwoofers. Immediate improvement in mid-bass and midrange as well as low bass. Dynamics improved; cleaner reproduction of mid-bass to midrange. Larger soundstage. I recommend these if you want all the music; you'll like them,"Audio.
2235H Low Frequency Loudspeaker: 380mm (15 in)
FEATURES:
300 W continuous program power capacity
100 mm (4 in}edgewound copper ribbon voice coil
20 Hz to 2 kHz response
93 dB sensitivity, 1 W@ 1 m
The JBL Model 2235H represents the latest developments in low frequency loudspeaker technology. It combines smooth response, extended low frequency bandwidth, and extremely low distortion, making it ideal for custom studio monitors and other critical applications requiring an optimum balance of efficiency and bass response.
The 2235H has a low-loss magnetic structure that weighs 8.5 kg (18 5/8 lb) and incorporates JBL's unique Symmetrical Field Geometry (SFG). This design, in combination with the aluminum Flux Stabilizing Ring around the pole piece, reduces second harmonic distortion to inconsequential levels. The 100 mm (4in) diameter voice coil benefits from new adhesive technology and optimized coil-former construction of aluminum, plastic and high temperature paper for increased power capacity. The 19 mm (3/4 in) length of the voice coil allows increased linear excursion capability and the extension of usable frequency response to 20 Hz in equalized alignments and subwoofer applications. Careful choice of suspension elements, taking into account their interaction with the voice coil motion, results in a driver with tight, controlled transient response and complete freedom from dynamic instabilities.
The heavy cast aluminum frame resists deformation and improves heat dissipation, and extremely tight manufacturing tolerances contribute to the high performance and linear frequency response.
SPECIFICATIONS
Nominal Diameter: 380 mm ( 15 in)
Rated Impedance: 8 ohms
Power Capacity: 300 W continuous program Continuous program power is defined as 3 dB greater than continuous sine wave power and is a conservative expression of the transducer's ability to handle typical speech and music program material
Sensitivity: (The sensitivity rating of JBL low frequency loudspeakers is based on a signal Swept from 100Hz to 500 Hz, rather than the conventional 1 kHz single frequency test signal since these drivers are usually used below 800 Hz Therefore, usable sensitivity of the 2202H may be substantially greater than that of loudspeakers with higher published ratings The half-space reference efficiency percentages will give a consistent method for comparison of E series, Professional Series, and competitive loudspeakers in low-frequency applications.) 93 dB SPL, 1 W. 1 m
Frequency Range: 20 Hz to 2 kHz
Highest Recommended Crossover Frequency: 1000 Hz
Recommended Enclosure Volume: 85-285 L (3-10 ft3)
Effective Piston Diameter: 337 mm ( 13 1/4 in)
Maximum Excursion Before Damage: 22 mm (7/8 in peak to peak)
Minimum Impedance: 7.0 ohms ± 10% @ 25°C
Voice Coil Diameter: 100 mm (4 in)
Voice Coil Material: Edgewound copper ribbon
Voice Coil Winding Depth: 191 mm (3/4 in)
Magnetic Gap Depth: 7.1 mm (0.28 in)
Magnetic Assembly Weight: 8.5kg
Flux Density: 1.2 T ( 12,000 gauss)
Bl Factor: 20.5 N/A
Effective Moving Mass: 0.155 kg Positive voltage on black terminal gives forward diaphragm motion.
THIELE - SMALL PARAMETERS:
fs: 20 Hz
Re: 6.0 ohms
Qts: 0.25
Qms: 2.5
Qes: 0.28
Vas: 460 L ( 16.2 ft3)
Sd: 0.089 m2 ( 138 in2)
Xmax: 8.5 mm (0.33 in)
Vd: 757 cm3 (46 in3)
Le: 1.2 mH
no (Half space)2: 1.3%
Pe (Max): 150 W Continuous sine wave
MOUNTING INFORMATION:
Overall Diameter: 388 mm (15 17/64 in)
Bolt Circle Diameter: 370 mm ( 14 9/16 in)
BAFFLE CUTOUT DIAMETER:
Front Mount: 355 mm (13 31/32 in)
Rear Mount: 343 mm ( 13 1/2 in)
Volume Displaced by Driver When Mounted in Enclosure: 6 L (0.2 ft3)
Depth: 137 mm (5 1/2 in)
Net Weight: 10.1 kg (22 1/4 lb)
Shipping Weight: 11.2 kg (24 3/4 lb)
Edited by - Niklas Nord on 2003/04/26 13:22:38
n/a
deleted
Posted - 2003/04/26 :  14:25:36  Show Profile Send n/a a Private Message
Sånna har jag haft . Kommer det att bli subbar av dom
”Mycket av världens elände är resultatet av i demokratisk ordning fattade beslut.”
- Olof Palme
Dimitri
Posted - 2003/04/26 :  14:39:29  Show Profile Send Dimitri a Private Message
Kul för dig NN!
Liten reflektion: Jag minns den där "Telarcen" från 80, om inte från 70-talet. Finns i merparten av reviews när man skriver om baskvaliteten. Vet faktiskt inte om det är skivetikett ellr ett verk. Men det har på något viss blivit så att är "Telarc" bra så är basen bra vilket är praktiskt vid snabbgenomläsning, "Telarcen" sticker ut direkt. Finns det verkligen så få inspelningar med den djupaste basen?
Dimitri
Niklas Nord
Posted - 2003/04/26 :  15:36:01  Show Profile Send Niklas Nord a Private Message
ja subbar blir det antagligen ja
n/a
deleted
Posted - 2003/04/26 :  15:52:33  Show Profile Send n/a a Private Message
Då vill jag rekommendera dig att inte göra samma miss som jag gjorde. Om du kör dom i stereo med två separata slutsteg så kommer du att få väldigt höga impedanstoppar på var sida om avstämmningen, nånstans mellan 40 och 50 ohm lite beroende på avstämning och dämpmaterial. Om vi säger 32ohm för enkelhetens skull så kommer ett 200watts steg bara att lämna 50watt vid dom frekvenserna (blir 35-40W alltså). Om du istället monokopplar dom halveras impedanstopparna och impedansen blir ändå inte särskilt låg i arbetsområdet, 3ohm blir det först uppe i 200hz-området. Vid portningen kommer du att ha 4-5 ohm. Att monokoppla under 50hz märker du inte av ändå. Jag har dock inte provat den här teorin i praktiken men jag tycker att resonemanget håller.
- Olof Palme
Edited by - n/a on 2003/04/26 16:15:45
mag
dom kallar oss mods
Posted - 2003/04/26 :  17:23:46  Show Profile Send mag a Private Message
Fegis, du skulle ju ha 18"are ;)
//Magnus
Born to lose -Live to win
neriks
Harry-vinnare 2004
Posted - 2003/04/26 :  23:13:49  Show Profile  Visit neriks's Homepage Send neriks a Private Message
NN,
Ohhhh !!! Då blir det snart en lyssnings-session hemma hos dig då?
Niklas Nord
Posted - 2003/04/26 :  23:15:40  Show Profile Send Niklas Nord a Private Message
Jasså du, men du har ju vart i stockholm flera ggr utan att komma in och kolla på mina högtalare som ligger i hörnen. jag räknade idag, och kom fram till 16st högtalarelement som låg på golvet! jag måste skaffa förvaring snart, detta kan ju inte vara bra i längden, tänk om golvet störtar samman. måste vara rätt många kilo JBL där nu!!!!!! - helt okej ellerhur!
neriks
Harry-vinnare 2004
Posted - 2003/04/26 :  23:26:13  Show Profile  Visit neriks's Homepage Send neriks a Private Message
NN,
Nästa gång jag besöker den kungliga huvudstaden så hör jag av mig ... Din eminenta samling JBL-element måste ju ses ... eller ännu hellre UPPLEVAS!!!
Niklas Nord
Posted - 2003/04/26 :  23:32:53  Show Profile Send Niklas Nord a Private Message
whiskeyprovning @ your place snart, även a fact!!
S E L E C T A
(har precis sett Ali G in da house!! )
hrmmm
neriks
Harry-vinnare 2004
Posted - 2003/04/26 :  23:41:44  Show Profile  Visit neriks's Homepage Send neriks a Private Message
NN,
Taget!!!
Jag drack whisky här hemma igår med några kollegor från jobbet. Framåt 22-snåret så var jag helt säker på att Dire Straits lirade live i min källare!!! Vilken dynamik och vilket j-kla tryck!!! Mark Knopfler och resten av gänget tackade för sig framåt midnatt då Neriks fick order av sin fru att gå och sova
Niklas Nord
Posted - 2003/04/26 :  23:48:14  Show Profile Send Niklas Nord a Private Message
härligt.
Mark själv skulle komma och spela för NN, men
så vurpade han på sin motorcykel och ställde in,
så nu blir det ingenting!
neriks
Harry-vinnare 2004
Posted - 2003/04/26 :  23:49:45  Show Profile  Visit neriks's Homepage Send neriks a Private Message
NN,
Han kommer säkert förbi dig någon annan gång
Niklas Nord
Posted - 2003/04/27 :  00:10:20  Show Profile Send Niklas Nord a Private Message
Kolla Neriks: http://www.jblpro.com/pub/obsolete/4842.pdf
VILKEN jäkla buttshaker
Tobias
Posted - 2003/04/27 :  10:40:15  Show Profile Send Tobias a Private Message
Från en annan tråd;
Originally posted by Niklas Nord
jo jag vet. men jag gillar inte 15", det skall vara 10" 12" eller 18"
just 15" är ett fjolltum
Kom igen NN, har du lagt ned smaken för det extrema? Du ska väl ha minst 18" basar
Edited by - Tobias on 2003/04/27 10:41:20
neriks
Harry-vinnare 2004
Posted - 2003/04/27 :  10:42:43  Show Profile  Visit neriks's Homepage Send neriks a Private Message
NN,
Det är riktigt synd att de inte tillverkas längre
Niklas Nord
Posted - 2003/04/27 :  11:07:42  Show Profile Send Niklas Nord a Private Message
Ja du Tobias, tyvärr är de så svåra att finna!
n/a
deleted
Posted - 2003/04/27 :  11:45:08  Show Profile Send n/a a Private Message
Jag har iofs två st e-155/8, du får väl lägga ett bud . Samma chassie som dom övriga artontummarna.
- Olof Palme
Niklas Nord
Posted - 2003/04/27 :  12:18:06  Show Profile Send Niklas Nord a Private Message
vad?
vad är det för element? föregångare till 2245?
är inte det dära elbaselement med silverdammkåpa?
n/a
deleted
Posted - 2003/04/27 :  12:55:11  Show Profile Send n/a a Private Message
Jo originalkonen har en aluminiumdammkåpa, men den ena som jag har är omkonad med samma kon men med samma dammkåpa som sitter på bla 2242h. Tanken med aluminiumkåpan var att få lite mer övertoner till elbasen.Konen är slät.
- Olof Palme
neriks
Harry-vinnare 2004
Posted - 2003/04/27 :  13:11:57  Show Profile  Visit neriks's Homepage Send neriks a Private Message
Dahlberg,
Hmmm ... instressant . E-155 har ju en SFG-magnet precis som 2245H ... Vet du om E-155 och 2245H delar samma typ av magnet och chassie?
I så fall borde man kunna kona om dessa till 2245H ... Det skulle vara något för dig NN
Alexi
Ute och cyklar...?
Posted - 2003/04/27 :  14:31:24  Show Profile  Visit Alexi's Homepage Send Alexi a Private Message
Som sagt 18" ska det vara!
Driver forumet faktiskt.se
n/a
deleted
Posted - 2003/04/27 :  15:46:29  Show Profile Send n/a a Private Message
Så här ser dom ut.
Edit: Korg till 2245H och data för E-155.
http://www.jblproservice.com/pdf/Discrete%20Sales%20Models/2245H.pdf
http://www.jblproservice.com/pdf/Discrete%20Sales%20Models/E155-4-8.pdf
http://www.jblpro.com/pages/pub/components/eseries.pdf
- Olof Palme
Edited by - n/a on 2003/04/27 16:39:02
neriks
Harry-vinnare 2004
Posted - 2003/04/27 :  16:09:47  Show Profile  Visit neriks's Homepage Send neriks a Private Message
Dahlberg,
Kul tråd det här . Vilka härliga bilder på dina element ... Av bilderna att dömma så ser det precis ut som att dessa har samma typ av manget och chassie som JBL 2245H.
Så här ser mina 2242:or ut ... Som du ser så är det samma chassie men olika typer av magneter. Magneten som sitter på 2242H har bättre kylning för talspolen och vilket tydligen ska minska den dynamiska kompressionen ...
P.S.
Här är ett bra dokument som beskriver skillnaderna mellan SFG, VGC och SVG tekniken som JBL använder i sina olika element ...
D.S.
neriks
Harry-vinnare 2004
Posted - 2003/04/27 :  16:45:20  Show Profile  Visit neriks's Homepage Send neriks a Private Message
Japp ... 2245H och E155 har samma magnet och chassie!
Gasket: 51272
Rear gasket: 60578
Magnet cover: 59642-01
Input terminals: 72792
Jämför man sedan dimensionerna mellan elementen så är dessa lika ...
JBL E-155
JBL 2245H
Edited by - neriks on 2003/04/27 16:45:41
neriks
Harry-vinnare 2004
Posted - 2003/04/27 :  16:56:33  Show Profile  Visit neriks's Homepage Send neriks a Private Message
NN,
Vid en närmare granskning av JBL 2240H så borde det faktiskt gå att även kona om JBL 2240H till JBL 2245H!
