 * Sålda *
ulfja
Posted - 2003/04/03 :  16:13:13  Show Profile Send ulfja a Private Message
Klipsch CF-2 högtalare säljes. De är extremt lättdrivna vilket gör att en liten förstärkare klarar av att driva dem.
Lite data:
FREQUENCY RESPONSE: 36Hz-20kHz±3dB
SENSITIVITY: 98dB @ 1watt/1meter
POWER HANDLING: 200 watts maximum continuous (800 watts peak)
NOMINAL IMPEDANCE: 8 ohms
ENCLOSURE TYPE: Bass reflex via front-mounted port
DRIVE COMPONENTS: Two-way system using one 2" (5.08cm) magnetically shielded, aluminum diaphragm compression driver with a 90°x60° Tractrix® Horn and
two 8" (20.32cm) neodymium magnet, poly carbon graphite cone woofers
TWEETER: K-64-KN 2" (5.08cm) Aluminum diaphragm compression driver
HIGH FREQUENCY HORN: 90°x60° Tractrix® Horn
HIGH FREQUENCY CROSSOVER: 2200Hz
WOOFER: Two K-1029-KN 8" (20.32cm) Poly carbon graphite cones
DIMENSIONS: 37" (93.98cm) x 13" (33.02cm) x 16" 40.64cm)
WEIGHT: 80 lbs. (36.29kg)
Nypriset var 14 900 kr, säljes för 6 500 kr.
Tele 070-5270314.
Edited by - ulfja on 2003/04/16 07:33:37
Tomas
Posted - 2003/04/10 :  14:47:02  Show Profile Send Tomas a Private Message
Vart finns dom?
