 Är det någon som använder Sample Champion
xCarlsson
Posted - 2003/04/02 :  21:18:06  Show Profile Send xCarlsson a Private Message
Är det någon som använder eller har hört något om Sample Champion?
http://www.purebits.com/
Of those who say nothing, few are silent
xCarlsson
Posted - 2003/04/02 :  21:33:27  Show Profile Send xCarlsson a Private Message
Mer Info från Hemsidan
Accurate, fast and powerful
Sample Champion is an accurate and easy to use audio measurement software. It has been designed for acoustical technicians, sound engineers, scientists and students. With this software you'll be able to easily perform Impulse response measurements, FFT analysis and much more.
Amazing features
Some very useful options are available, such as:
MLS pre-filtering (pink and/or custom spectrum)
synchronous averaging in time and frequency domain
double precision FFT of Impulse Response or Scope data
real-time results (the Impulse Response can be monitored during the averaging process)
possibility to calibrate the system using internal or external sources.
Expandable and versatile
Sample Champion has been designed with special attention to the possibility of future improvements and expansions. Special purpose signal processing plug-ins will be released.
Above features and much more are described in detail in the following section.
Plugins
Audio Quality Plugin
Filter Banks
Waterfall Plot
Room Acoustics
Enhanced View
Impedance
Wolfie
Posted - 2003/04/02 :  21:37:06  Show Profile  Visit Wolfie's Homepage Send Wolfie a Private Message
Inte provat, men jag läste lite om funktionerna i det. Det verkar ju vara lättanvänt och trevlig. Trist att det inte är gratis...
Trevliga funktioner, men det verkade fortfarande vara lite beta över det.
Alla funktionerna är väldigt enkla att implementera i ex. Matlab eller Maple el. dylik utvecklingsmiljö. Fast det är klart. Matlab kostar ju inte lite heller... ;)
Ingen ordning utan kaos!
