 Mycket bättre ljud nästan gratis!
Jogus
Posted - 2003/04/02 :  16:32:22  Show Profile  Visit Jogus's Homepage Send Jogus a Private Message
Jag har provat Nordost Eco3 spray med förbluffande resutat.
Det blir mjukare,öppnare,bättre ljudbild osv.osv
Man behandlar skivan ,släden, kablarna och elementen
Johan, Lefflers HIFI
Lefflers arbetare
www.lefflers.se
n0p
Posted - 2003/04/02 :  16:56:44  Show Profile Send n0p a Private Message
jahapp, och vad är det som denna spray säger sig göra? Rent tekniskt asså. Pris?
Exit Planet Dust
lambda
Kilroy was here
Posted - 2003/04/02 :  17:01:24  Show Profile Send lambda a Private Message
, låter som ett mirakel
Rebo
Posted - 2003/04/02 :  17:12:00  Show Profile Send Rebo a Private Message
Provat att sprayar i öronen?
Rebo
Posted - 2003/04/02 :  17:15:49  Show Profile Send Rebo a Private Message
Nop: Fanns lite info på deras hemsida.
"ECO 3 Cable Treatment counters a problem long ignored in the hi-fi industry — the build up of static charges on the surface of loudspeaker, signal and power cables. These surface charges can interfere with the signal and introduce background noise into a hi-fi or home theater system. After applying ECO 3 you will notice music sounds better defined with harshness removed. This proprietary formula, developed by Nordost, will work with any cable. It is also very effective for removing stray electrical charges that build up on Compact Discs."
