 Grym Jadis Defy 7, 2 x 100 W klass A
Knoppen
Posted - 2003/03/07 :  14:27:19  Show Profile Send Knoppen a Private Message
En kompis som har dåligt med internet, e-post o dylikt sätter jag in en annons för hans räkning:
-Franskt High-End rörslutsteg, Jadis DEFY 7, 2x100w klass A. Bestyckad med 6x6550/kanal. Nyservad, friska rör. Nypris idag ca 75.000:-, slumpas
för endast 32.500:- (bvsa !)
Ring Lasse, tel 070-924 44 06.
/ Johan /
Knoppen
Posted - 2003/03/07 :  14:33:45  Show Profile Send Knoppen a Private Message
Och en bild från Ardumans hemsida:
Knoppen
Posted - 2003/03/07 :  14:36:30  Show Profile Send Knoppen a Private Message
Och en bild till:
"Considered by many discerning listeners to be the world's finest stereo amplifier, the Class AB DEFY 7 boast (6) 6550s per channel, delivering 100 watts per side. It's massive black potted transformers sit astride a typically elegant gold accented chassis. Priced at $ 8,495.00 retail.
SPECIFICATIONS
Stereo Block
Nominal Power : 2 x 100W: at 1 Kz for 0.6% THD
Nominal Input Sensitivity: 0.775V
Bandwidth: 20-20000 at 0 dB
Input Impedance: 100K
Load Impedance: Adjustable 1,4,8,16 ohms: Internal Strapping
Power Supply: AC input voltage corresponding to the country of destination
Power Consumption: 240W
Tubes:
2 - ECC82/12AU7
4 - ECC83/12AX7/7025
12 - EL34/6CA7A
Dimensions: 48.5 x 22.5 x 53 cm 1 chassis
Weight: 32Kg"
jojje_guitar
Posted - 2003/03/07 :  14:39:07  Show Profile Send jojje_guitar a Private Message
O du grymma värld... varför har man det inte bättre ställt?!?!??
"How about some thinking, before you blow the chessboard clean?" - Roine Stolt, Wallstreet Voodoo
Knoppen
Posted - 2003/03/07 :  17:21:43  Show Profile Send Knoppen a Private Message
Knoppen
Posted - 2003/03/24 :  09:35:31  Show Profile Send Knoppen a Private Message
Upp!
Kanske behövs en liten repris?
