 Blue Circle Audio
Fideljr Posted - 2006/05/03 : 20:04:18
Här kommer lite snygga bilder på lite grejer från Blue Circle Audio (Kanada)
och andra märken
6   L A T E S T    R E P L I E S    (Newest First)
johan.björklund Posted - 2006/05/06 : 21:32:02
Läckert värre
daja Posted - 2006/05/03 : 23:37:41
Inga stora kylflänsar på dom blocken!
Fideljr Posted - 2006/05/03 : 23:16:26
Test på BC 206 (Poweramp) och Bc 3000 MKII (Preamp)
http://www.ultraaudio.com/twbas/twbas_20041015.htm
Fideljr Posted - 2006/05/03 : 21:22:27
BC 208
* mono hybrid power amplifier
* 215 watt into 8 ohms, 430 watt into 4 ohms
* use (4) 6922 tube for the input stage
* total capacitance over 1.2 Farad (1,200,000uF) both channels
* standard with 6ft BC68 power cord
*Cosmetic options same as other 200 series power amps.
Fideljr Posted - 2006/05/03 : 21:09:16
eller ska man satsa sina pengar på dessa saker
Gilbert Yeung of Blue Circle Audio does things his way. More than any product in his room, including his own BC208 monoblocks, he was proud of the Hello Kitty DVD player that he found on sale for $49.95 -- marked down from $150. It has component, composite and S-video video output along with two digital audio outputs. It was the perfect match for...
...Mary Lou, Blue Circle's female audio mannequin. [www.bluecircle.com]
Fideljr Posted - 2006/05/03 : 20:58:20
Lite mer bilder
http://www.soundstage.com/revequip/bluecircle_bc208.htm
Det liknar mycke hur en dator är uppbygg
Text och bild hämtad från Soundstage
"I've written about some of the best amplifiers on the planet, from the Lamm monoblocks I use as my reference to the wonderful Atma-Sphere MA-2 Mk II.3s. The Blue Circle BC208s are the finest pieces of audio equipment that I've heard from Gilbert Yeung; but more than this, they are the easiest amps to listen to -- on all types of music -- that I've had in my system. This feat alone puts them firmly in the company of the best amps I've heard, and makes them a Reviewers' Choice.
Blue Circle Audio BC208 Mono Amplifiers
Price: $24,995 USD per pair.
We put a jewel case next to the Blue Circle BC208 mono amp ($26,800/pair as shown) to demonstrate its immensity. It looks like a speaker that's been tipped onto its back. Like the other BC-series amps, the 220-watt '208 is a hybrid that uses 6922 tubes and power op-amps. The pair took Gilbert Yeung a month to build. [www.bluecircle.com]
