| T O P I C R E V I E W |
| Rene |
Posted - 2013/06/20 : 09:32:46 Så lander der snart sådan et par i Danmark.
Der er mulighed for demo efter aftale.
De vil komme til at spille sammen med Pass Labs XS300 XS Preamp.
The EggelstonWorks Ivy Signature is a Reference speaker whose development was truly based on being just that: a reference. Developed with legendary mastering engineer, Bob Ludwig, the Ivy continues to be the reference in main room at Gateway Mastering Studio. As it turns out, mastering engineers want the same things out of their system as any other music lover. The most important aspects of a speaker to an engineer are accuracy and musicality. Accuracy is obviously important to an engineer, but also to anyone interested in a truthful portrayal of music. Musicality is a little more elusive in many designs, but at EgglestonWorks this means the speakers are easy to listen to and are not fatiguing in any way. For engineers, this is important as they sit in front of their speaker for many hours each day. The Ivy Signature is impressive to behold. On the baffle, there are eight (8) drive units visible, but there is more. Behind each of the 6#8221; midrange drivers is two more drivers mounted in isobaric configuration. Similarly, behind each of the 12#8221; woofers is another 12#8221; driver. The result of this unusual use of isobaric loading is a speaker that reproduces music in an effortless and completely truthful manner that has an almost spooky realism. Whether you are a professional engineer or just a music lover, the Ivy Signature takes the EgglestonWorks philosophy of accuracy and musicality to a level that all will appreciate. SPECIFICATIONS Frequency response is from -4dB @ 13 Hz to well beyond 24,000 Hz. Efficiency is 88dB. Impedance is 7 Ohms, nominal. Minimum impedance is 5 Ohms. Tweeter: 1#8243; cloth dome. Mid-bass: Twelve 6#8243; double-magnet driver, with a 3#8243; voice coil diameter. Bass: Six 12#8221; woofers loaded in parallel chambers in pressure driven configuration.
vassagohifi.com |
