 Canon kamera död?
hjort Posted - 2010/04/02 : 11:38:39
Har en Canon digital ixus 70 som fungerat felfritt tills nu.
Efter att den varit oanvänd cirka ett halvår packade jag upp den och då visade displayen bara svart brus vid fotoläget.
Vid bildvisningsläget visar den redan tagna foton utan problem men alla nya foton blir svarta.
Tyvärr tror jag garantin är slut.
Vet någon om detta är ett "känt" problem?
6   L A T E S T    R E P L I E S    (Newest First)
mace Posted - 2010/11/16 : 11:13:28
Hur har det gått??
M
mace Posted - 2010/04/02 : 18:41:14
Kanske är slutaren?
A Simple Fix for a Stuck Shutter
Instruktioner i länken nedan.
Anonymous said...
Thanks a lot.
This is the second time in a week that I have this problem with my canon Ixus 70 and am now pretty certain that the shutter is stuck closed. I tried tapping it on a cloth padded bblock of wood and then tried the same while holding the shutter open (manual, flash off etc.)and the second time it reopened and everything's woking hunky dory.Thanks for the tip and hope it stays that way!
Herodotus.
Camera Repair said...
Well Anonymous with the SD750 and Herodotus with the IXUS 70 encouraged me to try something. I have an SD1000 with a stuck OPEN shutter that I had no desire to dissect to its lens level (was keeping it as a parts camera only). Pictures were way over exposed with wavy lines, especially when taken outdoors. But encouraged by the two intrepid adventurers above, I dug out this old camera from my parts box and commenced to tapping its side against wooden furniture. Low and behold the camera and its shutter are working properly again. Thus this is a valid fix for shutters stuck both open AND closed.
CR
Hela sidan här:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
M
mace Posted - 2010/04/02 : 18:18:16
http://forums.cnet.com/5208-7594_102-0.html?threadID=53316
http://pcforalla.idg.se/2.1054/1.83225
http://www.flickr.com/groups/s2is/discuss/72157600084622332/
http://www.imaging-resource.com/NEWS/1128958202.html
http://www.imaging-resource.com/badccds.html
Jag är osöker på om det kan vara detta som drabbat din kamera.
Din kamera heter nog Powershot SD1000 i USA.
Glöm ej att Du har tre års reklamationsrätt
M
mace Posted - 2010/04/02 : 18:07:39
Hur gammal är den?
Jag lyckades reklamera svärfars ixus för ett par år sedan, ska se om jag har kvar länkar mm.
Tydligen ett "vanligt" fel. Sensorn på vissa modeller/årgångar gillar inte värme och eller fukt,
OBS!! Vet ej om just Din modell har kan vara drabbad av detta fel!!
Återkommer!
/M
mace Posted - 2010/04/02 : 18:05:27
Canon black screen of death
lagun49 Posted - 2010/04/02 : 17:08:24
Linsskyddet?
Lars G *elak*
