 Vitus Audio i Asien igen
Fideljr Posted - 2005/07/04 : 09:00:54
Vitus är visst populär i Asien
http://www.avbuzz.com/event/album02/DSCF2490
Ni hittar också andra go saker på länken
23   L A T E S T    R E P L I E S    (Newest First)
Pjotre Posted - 2005/08/14 : 21:39:14
Jag kan bara hålla med.... Vitus SM-100 skapar en sådan magi i rummet så man tror man är på ort och ställe där det spelas. Alla hifisuperlativ i världen räcker inte till utan magi är rätt ord!
Har ni inte lyssnat på dem än så passa på nästa gång en butik har demo med dem!!!
Jorma Posted - 2005/08/14 : 21:25:32
Här är det översättningar av sammanfattningen från några olika Japanska hifitidningar.
Stereo" JAPAN July 2005
SL100
SM100
Speaker : T-3G (Vienna Acoustics)
Super Tweeter : EAS-10TH1000 (Technics)
CD Transport : CT-1 (Phase Tech)
DA Converter : DIGIC (Goldmund)
SACD Player : DSC-A100 (DENON)
Music :
Rossini, "L'Italiana in Algeri"
Stravinsky, "Firebird"
Beethoven, "Cello Sonata Variation"
Chaikovski, "Fifth Symphony"
Unlike other heavy high-power amplifiers, low-pass is not too exaggerate, not boomy. Vitus amplifiers are richly expressive and produce variety of sounds; soft, sharp, clear, dynamic, powerful, detailed, and natural.
These are the amplifiers that would be my lifetime partner.
Mr. Kawamata of Dynamic Audio. JAPAN 4Q2004
Here are the basic points:
1. I'm surprised to find that this Vitus SM-100 can go louder than many other more 'powerful' amplifiers even though it is rated at 100W/8 Ohms.
2. It reproduces the sound of the piano like I've never heard before. The reverberation and decay can be heard in to black (noise floor).
3. The bass is the most controlled I've ever encountered. The combination with the Mosquito Neo 1.2 loudspeaker produces the most
incredible deep bass without becoming boomy or unstable.
4. The soundstage is extremely wide, one can hear the stage size!
5. I thought I knew my CD collection inside out, but this amp extracts so much information from the source that I had to play my entire CD collection again. Now I realize just how much was missing.
6. The mid range is so sweet; just like the best tube amplifiers, but with better weight and low end of the best semiconductor amps, high frequencies are slightly soft, but without the nasty edge of others.
7. Overall I list this amplifier as one of the best sounding of today.
"Stereo Sound" JAPAN June 2005
Though SL100 is composed of thick aluminium panels, its appearance is elegant. SL100 produces delicate and detailed sound, same as SM100.
The sound is brilliant, clear, and pure, and when we play the string concert of classical music with SL100, it produces beautiful and natural harmony.
The weight of 24kg brings low-pass response and clearness to all bands.
Så för att avsluta där Fideljr började tråden:
"Vitus är visst populär i Asien"
Jorma Posted - 2005/08/14 : 21:16:38
Här är en översättning från Kinesiska från en resension i en Hongkongtidning:
Hifi Review in Hong Kong:
I have been a professional reviewer for more than 20 Years!! And the
Vitus Audio SM-100 is likely to be the best solid state power amplifier I have ever heard.
This resulted in the SM-100 getting the "Product of the Year award for best power Amplifier.
Jorma Posted - 2005/08/14 : 13:58:24
Här är hela apparatuppställningen.
I bakre raden är det alltså 4 st Vitus SM-101.
I mitten överst är det försteget Vitus SL-100.
Till vänster står Weiss cd och Dac och dom övriga i mitten och höger är strömrenare Powerplants från PS-Audio som SL-100 och Weiss-Dacen är inkopplade på.
Högtalarna är ProAc Response D100
Jorma Posted - 2005/08/14 : 01:31:51
Så har vi kommit till Grande Finale med en 2kanalsuppställning som heter duga åtminstone vad det gäller förstärkeriet. En biampinguppställning med 4 st. SM-101. Dessa bilder är från Vitus nya distributör i Hongkong och dom heter Radar:
Pac Posted - 2005/08/13 : 15:19:43
Hej,
det blev ett bildreportage av denna tråden, så den flyttas till rätt avdelning.
Jorma Posted - 2005/08/13 : 15:18:03
De veier det samme som før, eller er de tyngre?
Jag tror att Vitus sa att dom blir ungefär samma i vikt, men är inte riktigt säker på detta. Transformatorn som är den tyngsta biten är av samma storlek, men den är lite modifierad/optimerad. Det är lte mer kondensatorer i dom, men det är också mer ventilationshål i lock och botten.
cybwiz Posted - 2005/08/13 : 02:54:19
Supre bilder, Jorma
Jorma Posted - 2005/08/13 : 02:12:55
Här är baksidan och på SM-100 är set ett par kraftiga handtag som är fästade i bakplåten. På SM-101 sitter handtagen i en utstickare på bottenplåten:
Här ser man att det är samma låda till dessa monoblock som det är till stereoblocket. Med den skillnaden att här är ett par av ingångarna blindproppade:
Lite varningstexter som verkar lite kul, men som behövs av dom otroliga grejer som Vitus har berättat. Denna förstärkare är inget för "modifieringsexperter", dom är maximalt modifierade i standardskick. Texten att förstärkaren ska endast användas i horisontalläge är också på allvar då transformatorn väger så mycket att den kan kröka den 14 mm tjocka aluminiumplåten om den får hänga på sniskan!!!
Lite bilder på en riktigt häftig uppställning från Hongkong kommer någon gång längre fram.
Jorma Posted - 2005/08/13 : 02:00:38
På undersidan ser man att den är likadan som ovansidan förutom fötterna:
En detaljbild på Vitusloggan som finns på ovan och undersidan. Denna finns inte på SM-100:
Jorma Posted - 2005/08/13 : 01:56:24
Lite "de ja vu" från avbuzz, tror att jag har varit i den affären nångång...
Bilden från Hongkong är från Vitus tidigare distributör ABC.
Dom 2 sista bilderna är från Las Vegas CESmässan 2005.
Här kommer lite detaljbilder på SM-101.
Först på fronten. Den första och andra är likadan som SM-100:
Den tredje ser man att den inte ser likadan ut:
Nagra Posted - 2005/08/13 : 00:38:43
Jorma Posted - 2005/08/12 : 20:55:01
När vi nu är igång med bilder så tog jag några på senaste CESmässan i Las Vegas som jag inte hunnit lägga ut tidigare. Bättre sent än aldrig
Detta är Hans Ole Vitus med frugan Britta.
"Du får inte visa en bild härifrån med Britta, Ingen kommer att se förstärkarna eller något annat" sa Vitus.
Han har nog rätt
Här är en bild till från CES. Detta är Argentos rumm eller som ni kanske lägger märke till AVA. Det var enda gången jag sett denna logga och som det verkar sista. Till vänster står Ulrik som numera är ensam ägare av Argento och också ägare av Avalon Eidolon Diamondhögtalarna som ni kanske har sett i ett tidigare reportage från Danmark som PAC gorde.
Till höger är det Anders som grundade Argento och som designade kablarna. Han har bidragit med en hel del till Vitus design och är numera heltidsysselsatt med Vitus.
Jag har en bunt färskare bilder med en riktigt häftig uppställning från Vitus nya distributör i Hongkong, men som sedvanligt med sådana här bildreportage så får ni tåla er ett tag.
Ojdå, vi ligger tydligen på fel forum, nu kanske den bör flyttas till bidforumet istället. Eller hur PAC?
Jorma Posted - 2005/08/12 : 20:23:35
Här är en bild från Vitus förra distributör i Hongkong.
Vitus har bytt av skäl som jag inte känner till.
Detta är SM-100 som driver ett par Mosquitohögtalare.
Dom är ännu fulare från sidan och bakifrån, men det är fint material i lådorna. Kolfiber med aluminiumfrontar.
Argento stod för kablaget och Vitus har haft ett gott samarbete med Argento tidigare. Anders som var grundare av Argento jobbar nuförtiden med Vitus och har släppt taget om Argento.
Jorma Posted - 2005/08/12 : 20:12:54
- Betyder detta att de nya SM-101 prismässigt kommer att ligga över de "gamla" SM-100
//Eliot
Ja det kommer dom att göra, men exakt pris är inte riktigt klart ännu. Men enligt Hans Ole Vitus som jag hade ett långt och trevligt telefonsamtal med nyss -(på engelska så att det inte skulle bli några missförstånd pga. att Vitus inte förstår min Göteborska så bra)- så kommer det att handla om i storleksordningen runt 50000 dyrare.
Jag måste erkänna att jag har svårt med danskan också
eliot Posted - 2005/08/12 : 20:05:13
SM-100 Future
The introduction of the SM-101 does not suggest that the production of SM-100 will stop. We will
still keep production of the SM-100 running until further notice.
//Eliot
Jorma Posted - 2005/08/12 : 16:52:12
Jag tycker att SM-100 är snyggare så här direkt innan man hunnit vänja sig vid 101,ans utseende.
frugan tyckte precis tvärtom:
"Wow, va snygga dom var"
Så SM-101 kanske har en högre WAF
Här är lite bilder på SM-101:
Jorma Posted - 2005/08/12 : 16:16:09
Cybwiz
Ser at det er de nye SM-101 forsterkerne fra Vitus, vet noen hva som er forskjellen fra SM-100?
Jag har precis snackat med Vitus om SM-101 och han skickade över lite information:
ntroduction to the SM-101 mono amplifiers.
This document describes the main differences between the SM-100 and the SM-101.
SM-100 history:
The SM-100 was introduced at the Frankfurt show in May 2003. Since them it has been used at
several other shows like:
Shows:
1. Several private shows @ Peak Consult (Danish Speaker Manufacture) throughout
2003.
2. CES 2004 in the Argento, Soundlab & Vitus Audio room.
3. Private show @ Marten Design in Sweden, April 2004
4. Hong Kong exclusive show June 2004.
5. Taiwan shows in both Taichung and Taipei July 2004.
6. High end show in Tokyo October 2004.
7. Several smaller shows throughout Japan in 4Q04
8. CES 2005 in the Argento room and in the Vitus Audio room
9. Several other shows throughout Japan in 1H05
10. Focal private demo @ Focal in France March 2005
11. And many more…
Reviews:
1. HiFi Review, Hong Kong, issue 220 – 2004
2. Stereo Sound, Japan, issue 153 – 2004
3. Stereo Sound, Japan, June 2005 – together with the SL-100 Preamp.
Awards:
1. Product of the year award 2004 – HiFi Review, Hong Kong – 2004
Design:
The topology used in the SM-100 is based on more than 8 years research/development and uses
some very untraditional couplings. It is fully balanced from input to output and uses discrete
transistors only. The power supply used is single rail (Gnd and + 50V) with virtual gnd. The reason
for this topology of the power supply, what the intention to be able upgrade with a pure battery
supply, as used in our RP/RL-100 preamplifiers. However with the development of the current true
balanced preamplifier, SL-100, we found that the micro dynamic performance and speed was
limited, unless using extremely powerful batteries (4x 60Ah for the SL-100). This, combined with
the future lead free production regulations, resulted in a complete change in our strategy in not
using batteries in any new developed products – and directly lead to the development of our current
shunt regulated power supply used in both SP & SL-100.
With this change in strategy, and the new extended topology used in the new preamplifiers, (which
includes an optimised input stage for even better linearity), we felt that optimising the SM-100
design was in place.
SM-101 differences vs. SM-100
Mechanical differences:
1. Heat sinks – the side handles and heat sinks on the SM-100 have been replaced with one
massive heat sink resulting in much better heat dissipation.
2. Ventilation in both top and bottom – this together with the extended heat sinks – gives
overall better lifetime and lower chassis temperature.
3. Handlebars on the rear panel integrated in the bottom, which optimises comfort when
carrying the units, and minimises stress on the rear plate.
4. Top plate extended to cover and protect all connectors on the rear plate.
5. Front display window is wider and now made of real glass instead of plastic.
Electronically differences:
1. Input stage from the SP/SL-100 preamplifiers used – this results in better linearity overall.
2. Further input protection added, which grounds unused inputs.
3. Overall signal length decreased by 70%
4. Dual rail power supply (it now runs of +/- supply which is the traditional topology)
5. 188.000uF instead of 94.000uF in the main power supply.
6. Further optimised transformer for even lower magnetic influence of electronics and even
less voltage drop (from open to short).
7. DC servo’s optimised further for typical max. DC error of +/- 10mV.
8. All amplifier stages work spots optimised for achieving the best possible result with the
current topology.
9. Bi cabling allowed via extra set of binding posts.
Conclusion
With these changes we have achieved the next level in performance, purely by optimising current
technology. We have spent many hours making sure that the SM-101 was not only a “design”
upgrade, but a total new experience in both sound and design. The SM-100 has been known for its
overwhelming overall performance, and we are proud of the fact, that making it even better was
possible. The sound differences between the SM-100 and SM-101 are:
1. Even deeper bass with more details.
2. Sound staging much more precise and 3 dimensional.
3. Better resolution and micro dynamics.
We hope you find the SM-101 as exciting as us and wish you good listening.
SM-100 Future
LarsTokyo Posted - 2005/08/12 : 02:12:16
Jag såg ett par i Akihabara (Tokyos elektronikområde) häromdagen. De är klart feta!
I samma rum stod det utrustning för i runda slängar 5 miljoner kronor i form av de absolut fetaste JBL, JM Lab, B&W, Sonus Faber högtalare, samt en massa annat roligt. Varför har man inte djupa fickor?
Pjotre Posted - 2005/08/11 : 19:25:16
Sicka snygga slutsteg!!!
cybwiz Posted - 2005/08/11 : 18:15:24
Karbon stativene som forsterkerne står på er fra SR Composites.
Prisen for 1 par er ca 2500 usd.
global Posted - 2005/07/05 : 12:06:10
Jag gissar på granitplattor.
johan.björklund Posted - 2005/07/04 : 10:52:44
Undrar vad det är för bänk , massiva kolfiberplatter
