 Griffin Model 2 med ICEPower® på besøk!
thaugen Posted - 2004/04/26 : 02:44:53
Hmmm...dette spiller meget bra, skal stå her noen dager for test!
PS: Dette er en prototype uten finish (Finér/Lakk)
http://www.griffinspeaker.com/
Frequency response
40 - 25000 Hz (+/- 1.5 dB)
25 - 40000 Hz (-10 dB)
Harmonic distortion
less than 0.4% @ 96 dB SPL, 50-20000 Hz
Amplifier power
2 x 250 W, ICEPower® technology
Peak level @ 1 m
120 dB (two speakers, 1kHz)
Input
Analog audio on XLR/TRS combo connector, balanced or unbalanced
Input sensitivity
0 dBu produces 103 dB SPL @ 1 meter
Input impedance
25 k#8486;
Adjustments
Room correction EQ, -3 to +6 dB relative to half-space loading
Tweeter level, +/- 2 dB
Input sensitivity, +/- 6dB
Active crossover
2600 Hz, Linkwitz-Riley 4th order acoustic
Mains Power
230 V AC or 115 V AC 50/60 Hz (switchable inside the unit)
Power consumption
5 W idle
500 W maximum
Weight
31 kg
Physical dimensions
410 x 480 x 610 mm (WxDxH)
Finish
Real wood veneer
Custom finish upon request
1   L A T E S T    R E P L I E S    (Newest First)
Daffyd Posted - 2004/04/26 : 03:28:53
Feeling alright with the crew
Mvh.
David
